A problem about FLOATS
wjy
#1 Unread post by wjy »
HI ALL
I have #define FLOATS in *.h, the ROMS have read the float.in and creat the ocean_flt.nc. But,there is no data written in the ocean_flt.nc.Can you point the error i have made? Thank you!!!!!!!!!!!!
aearamos
Re: A problem about FLOATS
#2 Unread post by aearamos »
The same thing happened to me. I was using 1000 floats but most of them got no data! I'm running the model again with some changes to see if it works! What changes did you do in the *in file? How many floats did you use? Your z0 was negative or positive? Hope we can solve this!
Arthur Ramos
