Authorization failure
LRasmuson
#1 Unread post by LRasmuson »
I have been working to access the code with a subversion client,I have tried collabnet and X-Code, and I keep getting an authorization failure message. Below is the output from trying to access the subversion client through X-Code.
Error: 170001 (Authorization failed) Description: OPTIONS of 'https://lrasmuson@www.myroms.org/svn/src/trunk':
Am I missing a step to the process of accessing the code other than using the command lines that can be found in the wiki?
Leif
robertson
Re: Authorization failure
#2 Unread post by robertson »
If you need to specify a user name you should do it like this:
svn co --username lrasmuson https://www.myroms.org/svn/src/trunk my_dir
Putting it in the URL will not work.
Dave
robertson
#3 Unread post by robertson »
In your case that line should have been:
svn co --username LRasmuson https://www.myroms.org/svn/src/trunk my_dir
because user names are case sensitive.
Sorry for the confusion.
