I have encountered the compiling error when I tried to use the R4DVAR.
I used build.bash and got below result
I got the same result when I tried to compile the PSAS./opt/mpich2/bin/mpif90 -O3 -tp core2-64 /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/esmf_roms.o /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/master.o /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/ocean_control.o /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/ocean_coupler.o /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/propagator.o /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/roms_export.o /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/roms_import.o -o /home/ocean/model/trunk32/project/WC13/R4DVAR/oceanM /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libADM.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libADM_bio.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libRPM.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libRPM_bio.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libTLM.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libTLM_bio.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libNLM.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libNLM_bio.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libNLM_sed.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libANA.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libUTIL.a /home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libMODS.a -L/usr/local/netcdf/lib -lnetcdf -L/opt/ARPACK -lparpack -L/opt/ARPACK -larpack
/home/ocean/model/trunk32/project/WC13/R4DVAR/Build/libUTIL.a(posterior_var.o): In function `posterior_var_mod_posterior_var_tile_':
/home/ocean/model/trunk32/project/WC13/R4DVAR/Build/./posterior_var.f90:304: undefined reference to `dpotrf_'
/home/ocean/model/trunk32/project/WC13/R4DVAR/Build/./posterior_var.f90:314: undefined reference to `dpotri_'
make: *** [/home/ocean/model/trunk32/project/WC13/R4DVAR/oceanM] Error 2
I compiled I4DVAR successfully and the model was run without any problem.
Any suggestion would be great.
Regards,
-Peter
