Problem when running the upwelling application
alexmf
#1 Unread post by alexmf »
I have compiled the upwelling application on my linux PC but when trying to run it I get the following message:
root@arpoador:/home/alexandre/Projects/upwelling# ./oceanS < ocean_upwelling.in
"Process Information:
Thread # 0 (pid= 11616) is active.
Model Input Parameters: ROMS/TOMS version 3.4
Wednesday - August 25, 2010 - 8:03:53 PM
MOD_NCPARAM - Unable to open variable information file:
ROMS/External/varinfo.dat
Default file is located in source directory."
I have "varinfo.dat" copied into my Project/upwelling directoty. Also,my root and project directory paths seem correctly set on build.bash. Any help ? Thanks !
Re: Problem when running the upwelling application
the path to varinfo.dat is listed in the ocean_upwelling.in file. Make sure the path is correct from where you are running the model.
alexmf
#3 Unread post by alexmf »
Yes, I had the path wrongly set in "ocean_upwelling.in"
I've just fixed that. The application is running now.
Big thanks !!!!!
Alex
