possible bug in load_ts_metoffice.m?
kchen
#1 Unread post by kchen »
1. In matlab/4dvar/load_ts_metoffice.m, the 'epoch' is defined as datenum([1950 1 1 0 0 0]) but it's not being used. Probably should add: time=time+epoch, somewhere after line 187 and before line 228.
2. load_ts_metoffice.m, line 339 and 340:
    ind_T = find(Temp.time >= StartDay & Temp.time <= EndDay);
    ind_S = find(Salt.time >= StartDay & Salt.time <= EndDay);
probably should be
     ind_T = find(Temp.time > EndDay | Temp.time < StartDay );
     ind_S = find(Salt.time > EndDay | Salt.time < StartDay );
since ind_T and ind_S are those we wanna exclude...
Ke
Re: possible bug in load_ts_metoffice.m?
#2 Unread post by arango »
Yes, good catch. I did the time conditional differently. Please update. Thank you for reporting this problem.
