Possible bug in matlab/4dvar/d_std.m
hjsong
#1 Unread post by hjsong »
It is not about the ROMS code, but about the matlab code that is included tha package.
In the recent update, the scripts that compute the standard deviation have been changed a lot.
But mis-position of this one line causes very different result.
For the line 204-222 in d_std.m file look like this.
        for fval = field_list,
          field     = char(fval);           % convert cell to string
          field_avg = [field, '_avg'];      % average field
          field_std = [field, '_std'];      % standard deviation field
          try,
            F = nc_read(ncfile, field, rec);
            Rcount = Rcount + 1;
          catch,
            disp([' D_STD: error while processing, rec = ', num2str(rec)]);
            disp(['        for variable : ', field]);
            disp(['        in file: ', HisFile1]);
            return
          end,
          S.(field_avg) = S.(field_avg) + F;
          S.(field_std) = S.(field_std) + F.^2;
        end,
But 'Rcount = Rcount + 1' on line 212 should be out of the loop. Otherwise, it will be the sum of all records of all variables.
So, this seems to be changed like this
          try,
          catch,
            return
          end,
        end,
This is the same in 'd_std_unbalanced.m' and 'd_std_frc.m'.
Thank you.
Hajoon
Re: Possible bug in matlab/4dvar/d_std.m
#2 Unread post by arango »
Yes, good catch :oops: Thank you for reporting this bug. I introduced that bug in :arrow: src:ticket:461 when I updated the Matlab scripts.
Please update...
