Subversion checkout error on www.myroms.org
m.hadfield
I've tried to check out the new test directory on a couple of machines and got similar (not identical) errors on both
From a Subversion 1.3 client (yes this is very old):
$ svn checkout https://www.myroms.org/svn/src/test roms-test
svn: PROPFIND request failed on '/svn/src/test'
svn: PROPFIND of '/svn/src/test': 403 Forbidden (https://www.myroms.org)
From a Subversion 1.6 client:
$ $ svn checkout https://www.myroms.org/svn/src/test roms-test
svn: Server sent unexpected return value (403 Forbidden) in response to OPTIONS request for 'https://www.myroms.org/svn/src/test'
Adding a --username option to the command line doesn't help.
Re: Subversion checkout error on www.myroms.org
Yes, Mark. Thank you for your interest. This repository is restricted for now. Only three persons have access to it.
I mentioned this in the :arrow: ticket. I think that we are making the test repository available tomorrow. This is very complicated and we need to be completely sure that all the 4D-Var algorithms are working well in all provided tests. This is part up the of ROMS :arrow: Data Assimilation Workshop next month at University of California, Santa Cruz. Since this workshop is by invitation only, have around 40 participants, we want to make all the documentation, tests, homeworks available to everybody. This will be posted on the :arrow: Wiki ROMS and website.
m.hadfield
Thanks for the clarification.
m.hadfield
Hi again Hernan
In this ticket
https://www.myroms.org/projects/src/ticket/437
you say "The test repository is not open to everybody!" but I think what you mean is "The test repository is now open to everybody!".
#5 Unread post by arango »
Yes, thank you. I have been very busy today and didn't check for typos.
