(u,v)_visc not writing to diagnostics file
ggerbi
#1 Unread post by ggerbi »
Using revision 467 I found that the diagnostics were not writing the vertical velocity terms. It looks like this is due to missing code in inp_par.F.
I have added lines at 2767 that seem to have fixed this.
          ELSE IF (TRIM(KeyWord).eq.'Dout(M3vvis)') THEN
            IF (M3vvis.le.0) THEN
              IF (Master) WRITE (out,280) 'M3vvis'
              exit_flag=5
              RETURN
            Npts=load_l(Nval, Cval, Ngrids, Ldiag)
            DO ng=1,Ngrids
              Dout(idDu3d(M3vvis),ng)=Ldiag(ng)
              Dout(idDv3d(M3vvis),ng)=Ldiag(ng)
Also, I have not looked at this in detail, but inp_par.F may also be missing a couple lines for M3yvis around 4500 when compared to lines for M3xvis.
Re: (u,v)_visc not writing to diagnostics file
Yes, the processing of vertical mixing for momentum diagnostics and reporting Dout(M3yvis) were missing. Thank you for reporting this problem. I corrected the :arrow: repository.
