Hi all:
I want to run the couple ROMS and SWAN, and I run the INLET_TEST case at first, but I encounter some problem when executing oceanM. The following is the related informations with the errors marked in red, would you please help me resolve it?
qzhao@altix450:~/trunk> /opt/mpich2-ifort/bin/mpirun -np 2 ./oceanM ROMS/External/coupling_inlet_test.in
Coupled Input File name = ROMS/External/coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 000
Waves Model MPI nodes: 001 - 001
Process Information:
Node # 0 (pid= 68371) is active.
Model Input Parameters: ROMS/TOMS version 3.2
Monday - March 15, 2010 - 7:16:48 PM
SWAN is preparing computation ...
Inlet Test Case
Operating system : Linux
CPU/hardware : ia64
Compiler system : ifort
Compiler command : /opt/mpich2-ifort/bin/mpif90
Compiler flags : -ip -O3 -I/opt/mct/include -free
Input Script : ROMS/External/ocean_inlet_test.in
SVN Revision :
Local Root : /data1/qzhao/trunk
Header Dir : /data1/qzhao/trunk/ROMS/Include
Header file : inlet_test.h
Analytical Dir: /data1/qzhao/trunk/ROMS/Functionals
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 1, Tiling: 001x001
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
720 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-03 visc2 Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wave length.
T Hout(idWdir) Write out wave direction.
Physical parameters File: ROMS/External/ocean_inlet_test.in
Input Grid File: Data/ROMS/Grid/inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 75 1 70 42000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 75.50 0.50 70.50 RHO-points
0 1.00 75.00 0.50 70.50 U-points
0 0.50 75.50 1.00 70.00 V-points
HaloSizeI(1) = 255
HaloSizeJ(1) = 243
TileSide(1) = 79
TileSize(1) = 5925
Sediment Parameters, Grid: 01
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
tau_ce tau_cd tnu2 tnu4 Akt_bak Tnudg
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idSbed) Write out BED propFatal error in MPI_Irecv: Invalid datatype, error stack:
MPI_Irecv(144): MPI_Irecv(buf=0x60000000003a9790, count=1, INVALID DATATYPE, src=MPI_ANY_SOURCE, tag=1, MPI_COMM_WORLD, request=0x60000000003a9730) failed
MPI_Irecv(110): Null Datatype pointer
rank 0 in job 194 altix450_57952 caused collective abort of all ranks
exit status of rank 0: killed by signal 9
erty 03: bed_porosity
INLET_TEST Inlet Test Case
ANA_SEDIMENT Analytical sediment initial conditions.
EAST_FSGRADIENT Eastern edge, free-surface, gradient condition.
EAST_M2GRADIENT Eastern edge, 2D momentum, gradient condition.
EAST_M3GRADIENT Eastern edge, 3D momentum, gradient condition.
FSOBC_REDUCED Using free-surface data in reduced physics condtions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR Nearshore RAdiation Stress Terms.
NONLINEAR Nonlinear Model.
NORTH_FSGRADIENT Northern edge, free-surface, gradient condition.
NORTH_M2REDUCED Northern edge, 2D momentum, reduced-physics condition.
NORTH_M3GRADIENT Northern edge, 3D momentum, gradient condition.
SOUTHERN_WALL Wall boundary at Southern edge.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
THREE_GHOST Using three Ghost Points in halo regions.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
WEST_FSGRADIENT Western edge, free-surface, gradient condition.
WEST_M2GRADIENT Western edge, 2D momentum, gradient condition.
WEST_M3GRADIENT Western edge, 3D momentum, gradient condition.
problem when coupling roms and swan
- drews
Re: problem when coupling roms and swan
I was getting the same error messages shown in red above. The problem went away (and Inlet Test ran correctly) when I switched from
/usr/local/mpich2-1.3.1-pgf90/bin/mpirun
to
/usr/pgi/linux86/8.0/mpi/mpich/bin/mpirun
I suspect the problem came from a mismatch between the compilers used for building the MPI library, the MCT library, and oceanM (ROMS and SWAN).
to
