When adding tracer to river runoff using a NetCDF forcing file ROMs crashed when the tracer loop in the file get_data.F tried to load data for the first tracer after temperature and salt. idRtrc(3) was zero instead of the 152 that was set in mod_ncparam.F for the tracer.
Most things seemed fixed when I added idRtrc(inert(i))=varid just after idTvar(inert(i))=varid on line 1825 of mod_ncparam.F, except that stream inflow directions are all east-west (0) regardless of the values read from the forcing file. I'm trying to figure out what to do about that now.
bug in passive tracer loading in river runoff code
Re: bug in passive tracer loading in river runoff code
Yes, good catch. I guess that users are nowadays are using more complex applications with inert passive tracers (T_PASSIVE). Notice that we still don't have source and sink right-hand-side terms for the inert tracer equation as we have in the sediment and ecosystem models. It is very difficult to come up with a generalized formulation for this. I will probably will add a simple decay term in the future so user can customize their applications.
I updated the code, see the following ticket. Notice that the metadata definitions was also missing in varinfo.dat so this file was modified
Thank you for reporting this issue...
Thanks for updating the code.
I think I solved the problem in the second part of my posting--the part about river directions--by adjusting my u-mask and v-mask.
