where srflx is rescaled?
andreykoch
#1 Unread post by andreykoch »
In the Nonlinear/npzd_Powell.h the shortwave radiation flux srflx is given in [gradC*m/s] and is being rescaled back to [W/m2] to compute photosynthetically available radiation PARsur:
#ifdef CONST_PAR
! Specify constant surface irradiance a la Powell and Spitz.
PARsur(i)=158.075_r8
#else
PARsur(i)=PARfrac(ng)*srflx(i,j)*rho0*Cp
I have a hard time finding the place in the code where srflx is scaled to [gradC*m/s] from its proper units [W/m2].
I realize that somewhere it is multiplied by 1/(rho0*Cp) as it's done in Nonlinear/bulk_flux.F with Srad variable.
It would be a big help if someone could tell me that place in the code.
Andrey
Re: where srflx is rescaled?
This is very simple. Check inp_par.F around line 570 we have:
!  Convert momentum stresses and tracer flux scales to kinematic
!  Values. Recall, that all the model fluxes are kinematic.
        cff=1.0_r8/rho0
        Fscale(idUsms,ng)=cff*Fscale(idUsms,ng)
        Fscale(idVsms,ng)=cff*Fscale(idVsms,ng)
        Fscale(idUbms,ng)=cff*Fscale(idUbms,ng)
        Fscale(idVbms,ng)=cff*Fscale(idVbms,ng)
        Fscale(idUbrs,ng)=cff*Fscale(idUbrs,ng)
        Fscale(idVbrs,ng)=cff*Fscale(idVbrs,ng)
        Fscale(idUbws,ng)=cff*Fscale(idUbws,ng)
        Fscale(idVbws,ng)=cff*Fscale(idVbws,ng)
        Fscale(idUbcs,ng)=cff*Fscale(idUbcs,ng)
        Fscale(idVbcs,ng)=cff*Fscale(idVbcs,ng)
        cff=1.0_r8/(rho0*Cp)
        Fscale(idTsur(itemp),ng)=cff*Fscale(idTsur(itemp),ng)
        Fscale(idTbot(itemp),ng)=cff*Fscale(idTbot(itemp),ng)
        Fscale(idSrad,ng)=cff*Fscale(idSrad,ng)
        Fscale(idLdwn,ng)=cff*Fscale(idLdwn,ng)
        Fscale(idLrad,ng)=cff*Fscale(idLrad,ng)
        Fscale(idLhea,ng)=cff*Fscale(idLhea,ng)
        Fscale(idShea,ng)=cff*Fscale(idShea,ng)
        Fscale(iddQdT,ng)=cff*Fscale(iddQdT,ng)
Notice that during reading all the input fields are multiplied by the scale factor Fscale. In this case, Fscale(idTsur(itemp),ng) is used. The reason why this is done here and not in varinfo.dat is that the value of rho0 is not known because the input file ocean.in has not been read yet. Recall that this parameter is set by the user.
andreykoch
#3 Unread post by andreykoch »
Thank you for your reply. Then, could you point out where in the code Fscale(idSrad,ng) becomes srflx?
