Model blows up at 1st time step
lyzheng
#1 Unread post by lyzheng »
Hi, All,
I am using latest version of ROMS to run a case with one boundary (south). The initial conditions are 0 for seal level and velocities and climatological data for TS. The external forces include winds, heat fluxes, and rivers. Along the open boundary, the boundary file provides the sea level and transports as 0 (since there is not data) and TS as climatological data (constant during simulation period). The south edge open boundary conditions are SOUTH_FSCHAPMAN for sea level, SOUTH_M2FLATHER for transports, SOUTH_M3RADIATION for 3D velocities, and SOUTH_TRADIATION and SOUTH_TNUDGING for temperature and salinity.
When I run the model, it bows up at the 1st time step. The output file shows following message:
I STEP Day HH:MM:SS KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME
0 41225 00:00:00 0.000000E+00 1.260187E+04 1.260187E+04 4.315980E+14
DEF_HIS - creating history file: WFS_his.nc
DEF_AVG - creating average file: WFS_avr.nc
DEF_DIAGS - creating diagnostics file: WFS_dia.nc
DEF_STATION - creating stations file: WFS_sta.nc
DEF_FLOATS - creating floats file: WFS_flt.nc
1 41225 00:02:00 6.129442E-08 NaN NaN 4.315980E+14
WRT_RST - wrote re-start fields (Index=1,2) into time record = 0000001
Elapsed CPU time (seconds):
I check the input data from the output file and they are correct as input:
NLM: GET_STATE - Read state initial conditions, t = 41225 00:00:00
(File: ic72.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 5.09499979E+00 Max = 3.02528725E+01)
- salinity
(Min = 3.48903580E+01 Max = 3.65991669E+01)
(Min = 4.00000000E+00 Max = 1.16000000E+02)
(Min = 1.20000000E+01 Max = 7.50000000E+01)
(Min = 0.00000000E+00 Max = 2.00000000E-01)
GET_NGFLD - river runoff mass transport, t = 289 03:45:00
(Rec=0010, Index=2, File: river_clim2.nc)
(Tmin= 15.2188 Tmax= 350.0312)
(Min = 5.29000000E+01 Max = 8.80840000E+03)
GET_2DFLD - surface u-wind component, t = 41225 00:00:00
(Rec=0001, Index=1, File: atm72.nc)
(Tmin= 41225.0000 Tmax= 41591.0000)
(Min = -3.98408008E+00 Max = 1.93082631E+00)
GET_2DFLD - surface v-wind component, t = 41225 00:00:00
(Min = -3.10085535E+00 Max = 1.77354598E+00)
GET_2DFLD - surface air pressure, t = 41225 00:00:00
(Min = 1.00793756E+03 Max = 1.01813959E+03)
GET_2DFLD - cloud fraction, t = 41225 00:00:00
(Min = 7.00000003E-02 Max = 7.00000003E-02)
GET_2DFLD - solar shortwave radiation flux, t = 41225 00:00:00
(Min = 6.84567836E-12 Max = 6.84567836E-12)
GET_2DFLD - surface air temperature, t = 41225 00:00:00
(Min = 2.06800423E+01 Max = 2.76649666E+01)
GET_2DFLD - surface air relative humidity, t = 41225 00:00:00
(Min = 5.63671708E-01 Max = 9.72829878E-01)
GET_2DFLD - rain fall rate, t = 41225 00:00:00
(Min = 0.00000000E+00 Max = 2.65815161E-05)
GET_2DFLD - sea surface temperature climatology, t = 41225 00:00:00
(Rec=0001, Index=1, File: sst72.nc)
(Min = 2.38468552E+01 Max = 2.87542210E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 41225 00:00:00
(Min = -1.15740752E-05 Max = -1.15740752E-05)
GET_2DFLD - surface net freswater flux, (E-P), t = 41225 00:00:00
(Min = -8.67638432E-08 Max = -1.15116658E-10)
GET_NGFLD - free-surface southern boundary condition, t = 41225 00:00:00
(Rec=0001, Index=2, File: bc_nest72.nc)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 41225 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 41225 00:00:00
GET_3DFLD - potential temperature climatology, t = 41225 00:00:00
(Rec=0001, Index=1, File: nest72.nc)
GET_3DFLD - salinity climatology, t = 41225 00:00:00
Maximum grid stiffness ratios: rx0 = 0.000000E+00 (Beckmann and Haidvogel)
rx1 = 0.000000E+00 (Haney)
Initial basin volumes: TotVolume = 0.0000000000E+00 m3
MinVolume = 1.0000000000E+20 m3
MaxVolume = 0.0000000000E+00 m3
Max/Min = 0.0000000000E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00263520)
GET_NGFLD - river runoff mass transport, t = 319 14:15:00
(Rec=0011, Index=1, File: river_clim2.nc)
(Min = 4.30000000E+00 Max = 1.06833000E+04)
GET_2DFLD - surface u-wind component, t = 41225 06:00:00
(Rec=0002, Index=2, File: atm72.nc)
(Min = -5.01726055E+00 Max = 2.08626461E+00)
GET_2DFLD - surface v-wind component, t = 41225 06:00:00
(Min = -1.03191841E+00 Max = 2.52696967E+00)
GET_2DFLD - surface air pressure, t = 41225 06:00:00
(Min = 1.00754950E+03 Max = 1.01946692E+03)
GET_2DFLD - cloud fraction, t = 41225 06:00:00
(Min = 7.00000003E-02 Max = 8.00000012E-01)
GET_2DFLD - solar shortwave radiation flux, t = 41225 06:00:00
(Min = 6.84567836E-12 Max = 7.64232168E-07)
GET_2DFLD - surface air temperature, t = 41225 06:00:00
(Min = 1.90295238E+01 Max = 2.71164627E+01)
GET_2DFLD - surface air relative humidity, t = 41225 06:00:00
(Min = 6.26445651E-01 Max = 9.87701476E-01)
GET_2DFLD - rain fall rate, t = 41225 06:00:00
(Min = 0.00000000E+00 Max = 6.98466320E-05)
GET_2DFLD - sea surface temperature climatology, t = 41225 06:00:00
(Rec=0002, Index=2, File: sst72.nc)
(Min = 2.20039940E+01 Max = 2.87542210E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 41225 06:00:00
GET_2DFLD - surface net freswater flux, (E-P), t = 41225 06:00:00
(Min = -1.21943334E-07 Max = 2.19937052E-09)
GET_NGFLD - free-surface southern boundary condition, t = 41591 00:00:00
(Rec=0002, Index=1, File: bc_nest72.nc)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 41591 00:00:00
GET_NGFLD - 2D v-momentum southern boundary condition, t = 41591 00:00:00
GET_3DFLD - potential temperature climatology, t = 41591 00:00:00
(Rec=0002, Index=2, File: nest72.nc)
GET_3DFLD - salinity climatology, t = 41591 00:00:00
It is very likely caused by incorrect model setup. Does someone has the same thing happen before? Any comments are greatly appreciated.
Zheng
alazhar
Re: Model blows up at 1st time step
#2 Unread post by alazhar »
I see something weird in your basin volumes report where your max volume is zero.
maybe you need to recheck your grid setup.
lyzheng
#3 Unread post by lyzheng »
Thanks, Alazhar,
The grid input file can be correctly applied to ROMS version 3.0. I run version 3.0 using the same grid input file and it gets:
Maximum grid stiffness ratios: rx0 = 5.664869E-01 (Beckmann and Haidvogel)
rx1 = 1.730999E+01 (Haney)
Initial basin volumes: TotVolume = 4.30769841105073E+14 m3
MinVolume = 1.08564579831466E+06 m3
MaxVolume = 2.94063866737793E+10 m3
Max/Min = 2.70865384634926E+04
but if I run version 3.8, it gets:
Does this mean that for versions 3.0 and 3.8, the grid input files are different?
Thanks.
Zheng
