Tangent Linear Model Recipes
Discussion about tangent linear and adjoint models, variational data assimilation, and other related issues.
#1 Unread post by arango »
ROMS/TOMS has two tangent linear models one is based on perturbations to the model state and the other in full fields. The full fields tangent linear is only used for the indirect representer method.
Let's represent ROMS/TOMS nonlinear model (NLM) as follows:
      d(S)/d(t) = N(S)                                   (1)
where S is the model state with solution So and N(S) are the dynamical operators (usually nonlinear) like advection, Coriolis, pressure gradient, diffusion, etc. The tangent linear model (TLM) is derived by considering a small perturbation s to S, and performing a first-order Taylor expansion of (1) yielding (high-order terms are not considered):
      d(s)/d(t) = d{N(S)}/d{t} |  s  = A s               (2)
                                So
The adjoint model (ADM) is derived by considering the L2-norm inner-product of (2) with an arbitrary vector s' yielding:
     -d(s')/d(t) = A' s'                                 (3)
where A' is the adjoint of A. Similarly, the full fields tangent linear model for representers can be derived as:
      d(S')/d(t) = N(So) + A (S' - So)                   (4)
In ROMS/TOMS, we derived the representer tangent linear (RPM) code by adding the extra terms to the pertubation tangent linear model defined in (2).
The tangent linear and adjoint models are hand-coded using Geiring and Kaminski (1998) recipes. In the following recipes c is a constant and u, v, x, y are time-dependent model state variables.
   Nonlinear Code                      Tangent Linear Code
 f = c                               tl_f = 0
 f = x                               tl_f = tl_x
 f = c * x                           tl_f = c * tl_x
 f = x * x                           tl_f = 2 * x * tl_x
 f = x ** (n)                        tl_f = n * x ** (n-1) * tl_x
 f = x * y                           tl_f = tl_x * y + x * tl_y
 f = 1 / x                           tl_f = - f * f * tl_x
 f = 1 / SQRT(x)                     tl_f = - f * f * f * 0.5 * tl_x
 f = c / x                           tl_f = - c * tl_x / (x * x)
                                          = - f * tl_x / x
 f = x / y                           tl_f = (y * tl_x - x * tl_y) / (y * y)
 f = 1 / (x + y)                     tl_f = - f * f * (tl_x + tl_y)
 f = 1 / ((x + y)*(u + v))           tl_f = - f * f * (tl_x + tl_y) * (u + v)
                                            - f * f * (x + y) * (tl_u + tl_v)
 f = (c + u) / (x + y)               tl_f = + tl_u / (x + y)
 f = MAX(x, y)                       tl_f = (0.5 + SIGN(0.5, x - y)) * tl_x +
                                            (0.5 - SIGN(0.5, x - y)) * tl_y
 f = MAX(x, c)                       tl_f = (0.5 + SIGN(0.5, x - c)) * tl_x
 f = MAX(c, x)                       tl_f = (0.5 - SIGN(0.5, c - x)) * tl_x
 f = MIN(x, y)                       tl_f = (0.5 + SIGN(0.5, y - x)) * tl_x +
                                            (0.5 - SIGN(0.5, y - x)) * tl_y
 f = MIN(x, c)                       tl_f = (0.5 + SIGN(0.5, c - x)) * tl_x
 f = MIN(c, x)                       tl_f = (0.5 - SIGN(0.5, x - c)) * tl_x
 f = AINT(x)                         tl_f = 0.0
 f = ANINT(x)                        tl_f = 0.0
 f = MOD(x,y)                        tl_f = 0.0
 f = ABS(x)                          tl_f = SIGN(1.0,x) * tl_x
 f = SIGN(x,y)                       tl_f = SIGN(1.0, x) * SIGN(1.0, y) * tl_x + 0.0 * tl_y
 f = SIGN(c,x)                       tl_f = SIGN(1.0, c) * SIGN(1.0, x) * tl_c
                                          = 0.0
 f = SQRT(x)                         tl_f = 0.5 * tl_x / f
 f = SQRT(c/x)                       tl_f = - 0.5 * f * tl_x / x
 f = SQRT(x * x + y * y)             tl_f = (x * tl_x + y * tl_y) / f
 f = LOG(x)                          tl_f = tl_x / x
 f = 1/log(x)                        tl_f = - f * f * (tl_x / x)
 f = EXP(x)                          tl_f = EXP(x) * tl_x
 f = SIN(x)                          tl_f = COS(x) * tl_x
 f = COS(x)                          tl_f = - SIN(x) * tl_x
 f = TAN(x)                          tl_f = tl_x / (COS(x) * COS(x))
 f = TANH(x)                         tl_f = tl_x / (COSH(x) * COSH(x))
 f = SINH(x)                         tl_f = COSH(x) * tl_x
 f = COSH(x)                         tl_f = - SINH(x) * tl_x
 f = ASIN(x)                         tl_f = tl_x / SQRT(1.0 - x * x)
 f = ACOS(x)                         tl_f = - tl_x / SQRT (1.0 - x * x)
 f = ATAN(x)                         tl_f = tl_x / (1.0 + x * x)
 f = ATAN2(x,y)                      tl_f =  (y * tl_x - x * tl_y) / ( x * x + y * y)
So it is just variational calculus 8)
Representers tangent linear model recipes
#2 Unread post by arango »
The recipes for the RPM are derived using Taylor series expansion:
f(x) = f(xo +x')
     = f(xo) + (xo + x') df/dx
This can be illustrated with an example. Consider the product of two state variables x and y and let
x = xo + x'   and    x' = x - xo   (5)
y = yo + y'   and    y' = y - yo   (6)
where xo and yo are the basic state values and x' and y' are their perturbations. Then,
x * y = (xo + x') * (yo + y')
      =  xo * yo + x' * yo + xo * y' + x' * y'
Eliminating prime terms using (5) and (6) and neglecting high order terms involving prime variables  (i.e., x' * y') yield
x * y = xo * yo + (x - xo) * yo + xo * (y - yo)
      = xo * yo + x * yo - xo * yo + xo * y - xo * yo
      = x * yo + xo * y - xo * yo
using the above table nomeclature (tl_x=x, tl_y=y, x=xo and y=yo) we get
 f = x * y                           tl_f = tl_x * y + x * tl_y - x * y
                                          = tl_x * y + x * tl_y - f
Notice that to obtain the RPM from the TLM for the above expression, we just need to subtract x * y which is the same as f.
Therefore, the RPM can be derived by adding/subtracting extra term(s) to the TLM code as shown below.
   Nonlinear Code                      Representers Tangent Linear Code
 f = c                               tl_f = c
 f = x                               tl_f = tl_x
 f = x * x                           tl_f = 2 * x * tl_x - f
 f = x ** (n)                        tl_f = n * x ** (n-1) * tl_x - (n-1) * f
 f = x * y                           tl_f = tl_x * y + x * tl_y - f
 f = x * y * u                       tl_f = tl_x * y * u + x * (tl_y * u + y * tl_u) - 2 * f
 f = 1 / x                           tl_f = - f * f * tl_x + 2 * f
 f = 1 / (1 + x)                     tl_f = - f * f * tl_x + f * f * (1 + 2 * x)
 f = 1 / SQRT(x)                     tl_f = - f * f * f * 0.5 * tl_x + 1.5 * f
                                          = f * (1.5 - f * f * 0.5 * tl_x)
 f = c / x                           tl_f = - f * tl_x / x + 2 * f
                                          = f * (2 - tl_x / x)
 f = x / y                           tl_f = (y * tl_x - x * tl_y) / (y * y) + f
 f = (x * y) / u                     tl_f = (u * (tl_x * y + x * tl_y) - x * y * tl_u) / (u * u);   same!
 f = 1 / (x * y)                     tl_f = - f * f * (tl_x * y + x * tl_y) + 3 * f
 f = 1 / (x + y)                     tl_f = - f * f * (tl_x + tl_y) + 2 * f
                                          = f * (2 - f * (tl_x + tl_y))
                                            + 2 * f
 f = MAX(x, c)                       tl_f = (0.5 + SIGN(0.5, x - c)) * tl_x +
                                            (0.5 - SIGN(0.5, x - c)) * c
 f = MAX(c, x)                       tl_f = (0.5 - SIGN(0.5, c - x)) * tl_x +
                                            (0.5 + SIGN(0.5, c - x)) * c
 f = MIN(x, y)
 f = MIN(x, c)                       tl_f = (0.5 + SIGN(0.5, c - x)) * tl_x +
                                            (0.5 - SIGN(0.5, c - x)) * c
 f = MIN(c, x)                       tl_f = (0.5 - SIGN(0.5, x - c)) * tl_x +
                                            (0.5 + SIGN(0.5, x - c)) * c
 f = ABS(x)
 f = SQRT(x)                         tl_f = 0.5 * tl_x / f + 0.5 * f
                                          = 0.5 (f + tl_x / f)
 f = SQRT(c/x)                       tl_f = - 0.5 * f * tl_x / x + 0.5 * f
                                          = 0.5 * (f - f * tl_x / x)
 f = SQRT(x * x + y * y)             tl_f = ((x * tl_x + y * tl_y) / f)
 f = LOG(x)
 f = 1/log(x)
 f = EXP(x)                          tl_f = tl_x * f + (1 - x) * f
 f = EXP(c * x)                      tl_f = c * tl_x * f + (1 - c * x) * f
 f = SIN(x)                          tl_f = tl_x * COS(x) + f - x * COS(x)
 f = COS(x)
 f = TAN(x)
 f = SINH(x)
 f = COSH(x)
 f = ASIN(x)
 f = ACOS(x)
 f = ATAN(x)
 f = ATAN2(x,y)
