Why the DZmin and DZmax become NaN?
zhaoqian
Location: National Marine Environmental Mornitoring Center
#1 Unread post by zhaoqian »
When executing oceanM, some error occur and the program stop. The details are as follows:
Minimum X-grid spacing, DXmin = 1.39883582E+00 km
Maximum X-grid spacing, DXmax = 1.48958137E+00 km
Minimum Y-grid spacing, DYmin = 1.79470099E+00 km
Maximum Y-grid spacing, DYmax = 1.91112718E+00 km
Minimum Z-grid spacing, DZmin = NaN m
Maximum Z-grid spacing, DZmax = NaN m
Minimum barotropic Courant Number = 0.00000000E+00
Maximum barotropic Courant Number = 2.38484100E-01
Maximum Coriolis Courant Number = 2.86913724E-02
GET_NGFLD - tidal period
(Min = 4.32000000E+04 Max = 9.29494800E+04)
rank 1 in job 55 altix450_49117 caused collective abort of all ranks
exit status of rank 1: killed by signal 11
rank 0 in job 55 altix450_49117 caused collective abort of all ranks
exit status of rank 0: killed by signal 9
Will anybody tell me why the DZmax and DZmin become NaN? I created the grd file using seagrid.
I really appreciate your help!
Re: Why the DZmin and DZmax become NaN?
Do you know your minimum and maximum water depths? Are they nonzero everywhere?
zhaoqian
#3 Unread post by zhaoqian »
Thanks for your reply!
Do you mean that the depth should be nonzero in the water points and zero in the land points?
I find that in some water points,the depth is zero. This may be the reason why the error metioned occur. In order to avoiding this problem, i set the minimum depth to 5m when using seagrid to obtain depth of all grids.
The depth should be nonzero everywhere, both at sea and on land.
zhaoqian
#5 Unread post by zhaoqian »
Thank you very much! I have solve the problem following your advice.
