Bugs in fasham.F
m.hadfield
Bugs in fasham.F
A couple of bugs in ROMS 2.1 fasham.F, discovered while compiling on a Cray T3E with ASSUMED_SHAPE undefined:
  • 1) If none of the DIAGNOSTICS options is defined, then the Cray compiler issues a warning (non-fatal) about line 24...
          USE mod_diags
    ...because the module is empty. The warning can be suppressed by enclosing the line in an #ifdef block, ie
    # if defined DIAGNOSTICS_BIO
          USE mod_diags
    2) Line 116...
          real(r8), intent(in) :: z_w(LBi:UBi,LBj:UBj,UBk)
    ...is incorrect and should be...
          real(r8), intent(in) :: z_r(LBi:UBi,LBj:UBj,UBk)
Cheers
#2 Unread post by arango »
Yes, good catch :!:
Thank you, H
