Matlab version errors on ROMSTOOLS
feroda
#1 Unread post by feroda »
Recently, I am using ROMSTOOLS to setup my own application.
I met a problem about the matlab virsion. The error informations are as follow:
tiger@tiger-laptop:~/work/ROMS/input/ROMS_TOOL/Roms_tools/Run$ matlab -nojvm
< M A T L A B >
Copyright 1984-2007 The MathWorks, Inc.
Version 7.4.0.336 (R2007a)
January 29, 2007
To get started, type one of these: helpwin, helpdesk, or demo.
For product information, visit http://www.mathworks.com.
>> start Add the paths of the different toolboxes
Arch : unknown - Matlab version : 2007a
Arch : unknown you should provide the paths of your own loaddap and mexcdf directories
Does it mean that the Matlab version 2007a can NOT be used as the platform of ROMSTOOLS?
I think the tools should go well in Matlab R2007a.
What shell be done to fix this issue? Would someone please give me some kind advice?
Thank you very much!
susonic
Re: Matlab version errors on ROMSTOOLS
#2 Unread post by susonic »
Hi, there.
The tools which you are trying to use is from a different version of ROMS.
It's ROMS_Agrif from brest(France).
You'd better ask those questions
on http://roms.mpl.ird.fr/ which you downloaded the tools.
Good luck!
leonhardherrmann
#3 Unread post by leonhardherrmann »
Hi
the matlab version is not the problem
all you need to do there (i think) is to add the paths to the libraries
cd to the Run directory of roms
type >>open start
i have (somewhere near the end):
% ' you should provide the paths of your own loaddap and mexcdf directories'])
%end
rmpath /home/leo/softs/matlab/toolbox/symbolic
addpath /home/leo/softs/loaddap-3.6.1/
addpath /home/leo/ROMS_AGRIF/Roms_tools/mexnc
3rd line: rmpath... there was a problem with overlapping commands
then just "addpath" to the loaddap directory and the mexnc directory as above
I also commented out a lot of stuff between:
% Get the path to the mexcdf (it depends on the architecture)
% Comment all these lines if you don't want to pass in these tests
and the addpath bits shown above.
hope this makes sense,
good luck!
Leo
feroda
#4 Unread post by feroda »
Thanks! Leo is exactly right, I did so and the ROMS TOOLS goes pretty well.
susonic wrote:Hi, there.
Good luck!
Is there any tools like ROMS_TOOLS for the ROMS version here?
Thanks!
susonic
#5 Unread post by susonic »
viewtopic.php?t=916
viewtopic.php?t=1059
These two forums are helpful for you.
Regards,
feroda
#6 Unread post by feroda »
Thanks very much!
susonic wrote:viewtopic.php?t=916
Regards,
The tools you mentioned above are post-process tools for the visualization of ROMS output.
Actually, what I want to konw is the pre-process tools that for preparing the input Netcdf files.
Do you have any kind advice?
Thanks!
susonic
#7 Unread post by susonic »
The first one is visualization tools and the second one is for both visualization and preprocessing
tools http://eros.eas.gatech.edu/RNT/ here is the direct address.
Best,
