Dear users,
I have problems with values for horizontal viscosity coefficients. I have defined the Smagorinsky option in the cppdefs.h and I changed the visc3d value in roms.in. However the results did not change.
Does anyone have information on how can I change this coefficient??
As a beginner, I would appreciate any help.
Regards,
Re: horizontal viscosity coefficients
If you want to tune your Smagorinsky parameterization, you will need to find out where it is actually coming from. Once you have compiled the code, do a grep of visc3d on your Build directory. If hmixing.f90 shows up, you will see that there is a SmagorCoef constant set in that file. It isn't picking up anything from ocean.in as far as I can see.
kate,thanks very much for your reply!
