Hi
When compile I face to following error:
OPERATING SYSTEM IS: Linux
PROCESSOR IS: i686
cp: No match.
/bin/rm -rf core *.o AGRIFZOOM/AGRIF_YOURFILES/*.o *.i *.s *.f *.trace *.mod
/bin/rm -rf roms mpc cross_matrix cppcheck srcscheck checkkwds partit ncjoin ncrename ./rii_files
fpp -free -P -I../netcdf_ifc/ mpc.F > mpc.f
mpc.F(124): #warning: keyword redefined: integer
ifort -O3 -w90 -w95 -cm -72 -fno-alias -i4 -r8 -Vaxlib -openmp -o mpc mpc.f
fpp -free -P -I../netcdf_ifc/ main.F | ./mpc > main.f
main.F(371): #error: #if without #endif.
ifort -c -O3 -w90 -w95 -cm -72 -fno-alias -i4 -r8 -Vaxlib -openmp main.f -o main.o
fortcom: Error: main.f, line 290: Syntax error, found END-OF-FILE when expecting one of: <LABEL> <END-OF-STATEMENT> ; BLOCK BLOCKDATA PROGRAM TYPE COMPLEX BYTE CHARACTER ...
write(*,*) ' -3'
fortcom: Error: main.f, line 208: This label is undefined. [100]
if (ierr.ne.0) goto 100
fortcom: Error: main.f, line 221: This label is undefined. [99]
if (may_day_flag.ne.0) goto 99
compilation aborted for main.f (code 1)
gmake: *** [main.o] Error 1
mv: cannot stat `roms': No such file or directory
Everybody could help me for resolve problem thank so much.
Best Regards
F.Daryabor
compiling
Re: compiling
This is where I'd look - check your main.F. If the preprocessor is unhappy, it will create an incomplete main.f that the compiler is not happy with. Somewhere along the line, I picked up a Perl script to check for matching #if/#endif tests, which I'll attach here.main.F(371): #error: #if without #endif.
OK, that didn't work due to 'The extension is not allowed.' What the heck? Let's rename that sucker and try again...
ifdefs.F
- Perl script for checking #ifdefs.
- (1.5 KiB) Downloaded 431 times
Re: compiling
Hi kate
I have question, when I checked up Roms_Agrif directory I saw some of scripts was undefined for my case 'REGIONAL' and some of parameters for tracers (Temperature and Salinity) and baroclinic and barotropic mode was undefine thus I defined them for model ans so in main.F for example was undefined following line in main.F:
! Create climatological environment:
! Set nudging coefficient for sea surface hight and tracer
! climatology;
! Set bottom sediment grain size [m] and density [kg/m^3]
! used in bottom boundary layer formulation;
! Set initial analytical tracer climatology fields;
! Set initial sea surface height climatology;
#if defined TNUDGING || defined ZNUDGING || defined SPONGE \
|| (defined BBL && defined ANA_BSEDIM)\
|| (defined SEDIMENT && defined ANA_SEDIMENT)\
|| (defined TCLIMATOLOGY)\
|| (defined ZCLIMATOLOGY && defined ANA_SSH)
LINE AFTER DEFINE
! climatology;
# if defined BBL && defined ANA_BSEDIM
# if defined SEDIMENT && defined ANA_SEDIMENT
# if defined TCLIMATOLOGY
# if defined ZCLIMATOLOGY && defined ANA_SSH
next case for example in 'set_nudgcof.F' and 'set_nudgcof_fine.F' I define following line to script:
#if defined SCS
lon0=18.37
lat0=-33.91
rsponge=300.e3
cff=1./(50.*86400.)
cff1=Eradius*cos(lat0*deg2rad)*deg2rad
cff2=Eradius*deg2rad
do j=JstrR,JendR
do i=IstrR,IendR
dx=cff1*(lonr(i,j)-lon0)
dy=cff2*(latr(i,j)-lat0)
dr=sqrt(dx**2+dy**2)
if (dr .lt. rsponge) then
do k=1,N
Tnudgcof(i,j,k,itemp)=.5*cff*(cos(pi*dr/rsponge)+1)
& *(-atan((z_r(i,j,k)+750.)*2.e-2)/pi+.5)
Tnudgcof(i,j,k,isalt)=Tnudgcof(i,j,k,itemp)
enddo
endif
enddo
enddo
#else
subroutine set_nudgcof_fine_empty
#endif /* AGRIF && (TNUDGING || ZNUDGING || SPONGE) */
return
end
seem like this cases. whether is need that I touch to those?
Could you please guide me. Thank so much.
Best Regards
F.Daryabor
! climatology;
LINE AFTER DEFINE
! climatology;
#if defined SCS
lon0=18.37
lat0=-33.91
rsponge=300.e3
cff=1./(50.*86400.)
do j=JstrR,JendR
do i=IstrR,IendR
do k=1,N
enddo
endif
enddo
enddo
#else
return
end
Best Regards
F.Daryabor
Re: compiling
I've said it before - you are not using the flavor of ROMS which I am familiar with. If you need this level of help, you will have to switch ROMS or find someone who is more conversant with that ROMS. I suggest you look at the .f90 file after the preprocessor has been through the code - do what you need to do to get it right there.
