I'm trying to generate a grid using roms tools package. I had set up a romstools_param.m file for my grid but when I execute make_grid I got the following error message (below described) associated with m_proj.m routine
??? Improper index matrix reference.
Error in ==> m_proj at 69
k=m_match(proj,projections(:).name);
Error in ==> make_coast at 80
m_proj('mercator',...
Error in ==> make_grid at 174
make_coast(grdname,coastfileplot);
Does anyone knows what I'm doing wrong here?
thanks for the help
Problem in make_grid.m routine
Re: Problem in make_grid.m routine
Please post your romstools_param.m to understand the problem.
My guess is that the roms_grd.nc file was created and there is a problem plotting the domain. Check if you can find the roms_grd.nc file in the ROMS_FILES directory. If there is one, at least you can continue with your simulation.
Andres Sepulveda
Geophysics Department
University of Concepcion
Hi Andres
Thank you for your quickly reply. In Fact I've got to produce a roms_grd.nc file but when I opened it in matlab it seems that the routine didn't got to interpolate the bathymetry and the others forcing fields to the resolution that I ask for in my romstools_param.m file (attached in this message).
Thanks for the attention and help,
Luiz
% romstools_param: common parameter file for the preprocessing
% of ROMS simulations using ROMSTOOLS
% This file is used by make_grid.m, make_forcing.m,
% make_clim.m, make_biol.m, make_bry.m, make_tides.m,
% make_NCEP.m, make_OGCM.m, make_...
% Further Information:
% http://www.brest.ird.fr/Roms_tools/
% This file is part of ROMSTOOLS
% ROMSTOOLS is free software; you can redistribute it and/or modify
% it under the terms of the GNU General Public License as published
% by the Free Software Foundation; either version 2 of the License,
% or (at your option) any later version.
% ROMSTOOLS is distributed in the hope that it will be useful, but
% WITHOUT ANY WARRANTY; without even the implied warranty of
% MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
% GNU General Public License for more details.
% You should have received a copy of the GNU General Public License
% along with this program; if not, write to the Free Software
% Foundation, Inc., 59 Temple Place, Suite 330, Boston,
% MA 02111-1307 USA
% Copyright (c) 2005-2006 by Patrick Marchesiello and Pierrick Penven
% e-mail:Pierrick.Penven@ird.fr
% Updated 6-Sep-2006 by Pierrick Penven
% Updated 2006/10/05 by Pierrick Penven (add tidegauge observations)
% Updated 24-Oct-2006 by Pierrick Penven (diagnostics, chla etc...)
warning('on');
% 1 General parameters
% ROMS title names and directories
ROMS_title = 'Queiroz';
ROMS_config = 'Queiroz';
ROMSTOOLS_dir = 'C:\Litos\ROMS\tools\ROMS_TOOLS';
RUN_dir=[ROMSTOOLS_dir,'\Run\'];
ROMS_files_dir='c:\Litos\ROMS\tools\ROMS_TOOLS';
% ROMS file names (grid, forcing, bulk, climatology, initial)
grdname=['c:\Litos\ROMS\tools\ROMS_TOOLS\roms_queiroz_grd.nc'];
frcname=[ROMS_files_dir,'roms_queiroz_frc.nc'];
blkname=[ROMS_files_dir,'roms_queiroz_blk.nc'];
clmname=[ROMS_files_dir,'roms_queiroz_clm.nc'];
ininame=[ROMS_files_dir,'roms_queiroz_ini.nc'];
oaname =[ROMS_files_dir,'roms_queiroz_oa.nc']; % oa file : intermediate file not used
% in roms simulations
bryname=[ROMS_files_dir,'roms_queiroz_bry.nc'];
Zbryname=[ROMS_files_dir,'roms_queiroz_bry_Z.nc'];% Zbry file: intermediate file not used
frc_prefix=[ROMS_files_dir,'roms_queiroz_frc']; % generic forcing file name
% for interannual roms simulations (NCEP or GFS)
blk_prefix=[ROMS_files_dir,'roms_queiroz_blk']; % generic bulk file name
% Objective analysis decorrelation scale [m]
% (if Roa=0: simple extrapolation method; crude but much less costly)
%Roa=300e3;
Roa=0;
interp_method = 'cubic'; % Interpolation method: 'linear' or 'cubic'
makeplot = 0; % 1: create a few graphics after each preprocessing step
% 2 Grid parameters
% used by make_grid.m (and others..)
% Grid dimensions:
lonmin = -39.0; % Minimum longitude [degree east]
lonmax = -38.5; % Maximum longitude [degree east]
latmin = -16.5; % Minimum latitude [degree north]
latmax = -14.5; % Maximum latitude [degree north]
%lonmin = -55.0; % Minimum longitude [degree east]
%lonmax = -30.0; % Maximum longitude [degree east]
%latmin = -35.0; % Minimum latitude [degree north]
%latmax = -15.0; % Maximum latitude [degree north]
% Grid resolution [degree]
dl = 1/15;
% Number of vertical Levels (! should be the same in param.h !)
N = 15;
% Vertical grid parameters (! should be the same in roms.in !)
theta_s = 8.;
theta_b = 0.;
hc =10.;
% Minimum depth at the shore [m] (depends on the resolution,
% rule of thumb: dl=1, hmin=300, dl=1/4, hmin=150, ...)
% This affect the filtering since it works on grad(h)/h.
hmin = 2.;
% Maximum depth at the shore [m] (to prevent the generation
% of too big walls along the coast)
hmax_coast = 1500;
% Topography netcdf file name (ETOPO 2 or any other netcdf file
% in the same format)
topofile = [ROMSTOOLS_dir,'\Topo\etopo2.nc'];
% Slope parameter (r=grad(h)/h) maximum value for topography smoothing
rtarget = 0.25;
% Number of pass of a selective filter to reduce the isolated
% seamounts on the deep ocean.
n_filter_deep_topo=1;
% Number of pass of a single hanning filter at the end of the
% smooting procedure to ensure that there is no 2DX noise in the
% topography.
n_filter_final=1;
% GSHSS user defined coastline (see m_map)
% XXX_f.mat Full resolution data
% XXX_h.mat High resolution data
% XXX_i.mat Intermediate resolution data
% XXX_l.mat Low resolution data
% XXX_c.mat Crude resolution data
coastfileplot = 'coastline_l.mat';
coastfilemask = 'coastline_l_mask.mat';
% 3 Surface forcing parameters
% used by make_forcing.m and by make_bulk.m
% COADS directory (for climatology runs)
coads_dir=[ROMSTOOLS_dir,'\COADS05\'];
% COADS time (for climatology runs)
coads_time=(15:30:345); % days: middle of each month
coads_cycle=360; % repetition of a typical year of 360 days
%coads_time=(15.2188:30.4375:350.0313); % year of 365.25 days in the case
%coads_cycle=365.25; % of QSCAT experiments with
% climatological heat flux.
% 3.1 Surface forcing parameters
% used by pathfinder_sst.m
pathfinder_sst_name=[ROMSTOOLS_dir,...
'\SST_pathfinder\climato_pathfinder.nc'];
% 4 Open boundaries and initial conditions parameters
% used by make_clim.m, make_biol.m, make_bry.m
% Open boundaries switches (! should be consistent with cppdefs.h !)
obc = [1 1 0 0]; % open boundaries (1=open , [S E N W])
%obc = [0 1 1 0]; % open boundaries (1=open , [S E N W])
% Level of reference for geostrophy calculation
zref = -400;
% Switches for selecting what to process in make_clim (1=ON)
% (and also in make_OGCM.m and make_OGCM_frcst.m)
makeini=1; %1: process initial data
makeclim=1; %1: process lateral boundary data
makebry=1; %1: process boundary data
makeoa=1; %1: process oa data (intermediate file)
insitu2pot=1; %1: transform in-situ temperature to potential temperature
makeZbry=1; %1: process data in Z coordinate
% Day of initialisation for climatology experiments (=0 : 1st january 0h)
tini=0;
% World Ocean Atlas directory (WOA2001 or WOA2005)
woa_dir=[ROMSTOOLS_dir,'\WOA2005\'];
% Surface chlorophyll seasonal climatology (WOA2001 or SeaWifs)
chla_dir=[ROMSTOOLS_dir,'\SeaWifs\'];
% Set times and cycles for the boundary conditions:
% monthly climatology
woa_time=(15:30:345); % days: middle of each month
woa_cycle=360; % repetition of a typical year of 360 days
%woa_time=(15.2188:30.4375:350.0313); % year of 365.25 days in the case
%woa_cycle=365.25; % of QSCAT experiments with
% climatological boundary conditions
% 5 Parameters for tidal forcing
% TPXO file name (TPXO6 or TPXO7)
tidename=[ROMSTOOLS_dir,'\TPXO7\TPXO7.nc'];
% Number of tides component to process
Ntides=10;
% Chose order from the rank in the TPXO file :
% "M2 S2 N2 K2 K1 O1 P1 Q1 Mf Mm"
% " 1 2 3 4 5 6 7 8 9 10"
tidalrank=[1 2 3 4 5 6 7 8 9 10];
% Compare with tidegauge observations
%lon0=-4.60;
%lat0=48.42; % Brest location
%Z0=4; % Mean depth of the tidegauge in Brest
%lon0=18.37;
%lat0=-33.91; % Cape Town location
%Z0=1; % Mean depth of the tidegauge in Cape Town
%lon0=-40;
%lat0=-22; % Estação F1N - PROCAP2000
lon0=-49.285;
lat0=3; % Estação PENROD
% 6 Temporal parameters (used for make_tides, make_NCEP, make_OGCM)
Yorig = 1900; % reference time for vector time
% in roms initial and forcing files
Ymin = 2007; % first forcing year
Ymax = 2007; % last forcing year
Mmin = 1; % first forcing month
Mmax = 12; % last forcing month
Dmin = 1; % Day of initialization
Hmin = 0; % Hour of initialization
Min_min = 0; % Minute of initialization
Smin = 0; % Second of initialization
SPIN_Long = 0; % SPIN-UP duration in Years
% 7 Parameters for Interannual forcing (SODA, ECCO, NCEP, ...)
% Path to Forcing data
FORC_DATA_DIR = [RUN_dir,'DATA\'];
Download_data = 1; % Get data from the OPENDAP sites
level = 0; % AGRIF level; 0=parent grid
% Options for make_NCEP
NCEP_dir= [ROMS_files_dir,'NCEP_',ROMS_config,'\']; % NCEP data directory
makefrc = 1; % 1: Create forcing files
makeblk = 1; % 1: Create bulk files
add_tides = 0; % 1: Add the tides (To be done...)
NCEP_version = 1; % NCEP version:
% (1: NCEP/NCAR Reanalysis, 1/1/1948 - present
% 2: NCEP-DOE Reanalysis, 1/1/1979 - 12/31/2001)
% Options for make_OGCM
%OGCM = 'ECCO';
OGCM = 'SODA'; % Select the OGCM: SODA, ECCO, ...
OGCM_dir = [ROMS_files_dir,OGCM,ROMS_config,'\']; % OGCM data directory
bry_prefix = [ROMS_files_dir,'roms_bry_',OGCM,'_']; % generic boundary file name
clm_prefix = [ROMS_files_dir,'roms_clm_',OGCM,'_']; % generic climatology file name
ini_prefix = [ROMS_files_dir,'roms_ini_',OGCM,'_']; % generic initial file name
OGCM_prefix = [OGCM,'_']; % generic OGCM file name
rmdepth = 2; % Number of bottom levels to remove
% (This is usefull when there is no valid data at this level
% i.e if the depth in the domain is shallower than the OGCM depth)
% Options for make_QSCAT_daily and make_QSCAT_clim
QSCAT_dir = [FORC_DATA_DIR,'QSCAT_',ROMS_config,'\']; % QSCAT data directory.
QSCAT_frc_prefix = [frc_prefix,'_QSCAT_']; % generic forcing file name
% for interannual roms simulations with QuickCAT.
QSCAT_clim_file = [ROMSTOOLS_dir,'QuikSCAT_clim\',... % QuikSCAT climatology
'QSCAT_global_clim_jul99_aug06.nc']; % file for make_QSCAT_clim.
% 8 Parameters for the forecast system
FRCST_dir = [FORC_DATA_DIR,'Forecast\']; % path to store local OGCM data
FRCST_prefix = [OGCM,'_']; % generic OGCM file name
% 9 Parameters for the diagnostic tools
DIAG_dir = [ROMSTOOLS_dir,'Diagnostic_tools\'];
Luiz
% MA 02111-1307 USA
warning('on');
%Roa=300e3;
Roa=0;
% 2 Grid parameters
% Grid dimensions:
dl = 1/15;
N = 15;
theta_s = 8.;
theta_b = 0.;
hc =10.;
hmin = 2.;
hmax_coast = 1500;
rtarget = 0.25;
% topography.
n_filter_final=1;
zref = -400;
tini=0;
Ntides=10;
%lon0=-4.60;
%lon0=18.37;
%lon0=-40;
lon0=-49.285;
%OGCM = 'ECCO';
Hi Iassad,
Here are some observations on your romstools_param.m that may be the source of your problem:
"grdname=['c:\Litos\ROMS\tools\ROMS_TOOLS\roms_queiroz_grd.nc'];"
I do not know why you specifed this path, but the routine make_grid.m may not find the grid if you save it in another directory. To save yourself some trouble just save it in [ROMS_files_dir,'roms_queiroz_grd.nc'] as with the forcing and climatology files.
Secondly you have:
It is okay to reduce your hmin for simulations near the coastline where depth is small; nevertheless I recommend you follow the thumb rule suggested in the routine. hmin should be about 50 to 75m. If you would like to reduce hmin always remember that hmin > hc, otherwise you will have another error.
You are also missing to specify h_max. In my routine it goes like this:
Finally verify that you have the routines:
I ran make_grid with this specifications and it worked for me. Here is my romstools_param.m file:
% MA 02111-1307 USA
% Updated 08-Apr-2009 by Gildas Cambon
% Updated 23-Oct-2009 by Gildas Cambon
% Updated 17-Nov-2011 by Pierrick Penven (CFSR)
% ROMSTOOLS directory
ROMSTOOLS_dir = '../';
% Run directory
RUN_dir=[pwd,'/'];
% ROMS input netcdf files directory
ROMS_files_dir=[RUN_dir,'ROMS_FILES/'];
% Global data directory (etopo, coads, datasets download from ftp, etc..)
DATADIR=ROMSTOOLS_dir;
% Forcing data directory (ncep, quikscat, datasets download with opendap, etc..)
FORC_DATA_DIR = [RUN_dir,'DATA/'];
eval(['!mkdir ',ROMS_files_dir])
bioname=[ROMS_files_dir,'roms_frcbio.nc']; %Iron Dust forcing
%file with PISCES
grdname=[ROMS_files_dir,'roms_grd.nc'];
frcname=[ROMS_files_dir,'roms_frc.nc'];
blkname=[ROMS_files_dir,'roms_blk.nc'];
clmname=[ROMS_files_dir,'roms_clm.nc'];
ininame=[ROMS_files_dir,'roms_ini.nc'];
oaname =[ROMS_files_dir,'roms_oa.nc']; % oa file : intermediate file not used
bryname=[ROMS_files_dir,'roms_bry.nc'];
Zbryname=[ROMS_files_dir,'roms_bry_Z.nc'];% Zbry file: intermediate file not used
frc_prefix=[ROMS_files_dir,'roms_frc']; % generic forcing file name
blk_prefix=[ROMS_files_dir,'roms_blk']; % generic bulk file name
%Roa=300e3;
Roa=0;
interp_method = 'linear'; % Interpolation method: 'linear' or 'cubic'
makeplot = 1; % 1: create a few graphics after each preprocessing step
% 2 Grid parameters
% Grid dimensions:
dl = 1/15;
N = 15;
theta_s = 8.;
theta_b = 0.;
hc = 10.;
hmin = 50;
hmax_coast = 1500;
% Maximum depth [m] (cut the topography to prevent
% extrapolations below WOA data)
hmax = 5000;
topofile = [DATADIR,'Topo/etopo2.nc'];
rtarget = 0.25;
n_filter_deep_topo=4;
% topography.
n_filter_final=2;
Secondly you have:
hc =10.;
hmin = 2.;
hmin = 50;
hmax_coast = 1500;
hmax = 5000;
% MA 02111-1307 USA
% Run directory
RUN_dir=[pwd,'/'];
%file with PISCES
%Roa=300e3;
Roa=0;
% 2 Grid parameters
% Grid dimensions:
dl = 1/15;
N = 15;
theta_s = 8.;
theta_b = 0.;
hc = 10.;
hmin = 50;
hmax_coast = 1500;
hmax = 5000;
rtarget = 0.25;
% topography.
n_filter_final=2;
Hi Andres,
I`ve got to run make_grid.m using the roms_param file changes suggested by you but the problem seems to be related not only with these changes but also with the version of my m_map matlab package. The make_grid only worked when I installed a new version of this package.
Thanks again for your help,
Luiz
Luiz
