Trying to compile
lteeter
Trying to compile
#1 Unread post by lteeter »
I'm new to ROMS, and trying to compile using make -f makefile_BaseRun (I got a version from someone else, so I'm trying to run her specific base run), and I'm getting this:
makefile_BaseRun:230: INCLUDING FILE Compilers/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
make: *** No rule to make target `Build/MakeDepend', needed by `all'. Stop.
Any suggestions?
Re: Trying to compile
One of the first things make will try to do on a fresh build is to create that file. For some reason, this didn't happen, so I would first try "make -f makefile_BaseRun clean" and "make -f makefile_BaseRun depend". Does it create Build/MakeDepend? If not, was there a useful error message?
lteeter
#3 Unread post by lteeter »
for the "make -f makefile_BaseRun clean", I get:
rm -f -r core *.ipo Build Compilers/make_macros.mk
and for "make -f makefile_BaseRun depend" I get:
./ROMS/Bin/sfmakedepend --cpp --fext=f90 --file=- --objdir=Build -DROMS_HEADER="bioupw_newgrid.h" -I ROMS/Include -I ROMS/Nonlinear -I ROMS/SeaIce -I ROMS/Utility -I ROMS/Drivers -I ROMS/Functionals -I /home/lteeter/BioUPW -I Master -I Compilers --silent --moddir Build ROMS/Nonlinear/bbl.F ROMS/Nonlinear/bc_2d.F ROMS/Nonlinear/bc_3d.F ROMS/Nonlinear/bc_bry2d.F ROMS/Nonlinear/bc_bry3d.F ROMS/Nonlinear/biology.F ROMS/Nonlinear/bulk_flux.F ROMS/Nonlinear/bvf_mix.F ROMS/Nonlinear/conv_2d.F ROMS/Nonlinear/conv_3d.F ROMS/Nonlinear/conv_bry2d.F ROMS/Nonlinear/conv_bry3d.F ROMS/Nonlinear/diag.F ROMS/Nonlinear/exchange_2d.F ROMS/Nonlinear/exchange_3d.F ROMS/Nonlinear/forcing.F ROMS/Nonlinear/frc_adjust.F ROMS/Nonlinear/get_data.F ROMS/Nonlinear/get_idata.F ROMS/Nonlinear/gls_corstep.F ROMS/Nonlinear/gls_prestep.F ROMS/Nonlinear/hmixing.F ROMS/Nonlinear/ini_fields.F ROMS/Nonlinear/initial.F ROMS/Nonlinear/interp_floats.F ROMS/Nonlinear/lmd_bkpp.F ROMS/Nonlinear/lmd_skpp.F ROMS/Nonlinear/lmd_swfrac.F ROMS/Nonlinear/lmd_vmix.F ROMS/Nonlinear/main2d.F ROMS/Nonlinear/main3d.F ROMS/Nonlinear/mpdata_adiff.F ROMS/Nonlinear/my25_corstep.F ROMS/Nonlinear/my25_prestep.F ROMS/Nonlinear/obc_adjust.F ROMS/Nonlinear/obc_volcons.F ROMS/Nonlinear/omega.F ROMS/Nonlinear/output.F ROMS/Nonlinear/pre_step3d.F ROMS/Nonlinear/prsgrd.F ROMS/Nonlinear/radiation_stress.F ROMS/Nonlinear/rho_eos.F ROMS/Nonlinear/rhs3d.F ROMS/Nonlinear/sed_bed.F ROMS/Nonlinear/sed_bedload.F ROMS/Nonlinear/sed_fluxes.F ROMS/Nonlinear/sediment.F ROMS/Nonlinear/sed_settling.F ROMS/Nonlinear/sed_surface.F ROMS/Nonlinear/set_avg.F ROMS/Nonlinear/set_data.F ROMS/Nonlinear/set_depth.F ROMS/Nonlinear/set_massflux.F ROMS/Nonlinear/set_tides.F ROMS/Nonlinear/set_vbc.F ROMS/Nonlinear/set_zeta.F ROMS/Nonlinear/step2d.F ROMS/Nonlinear/step3d_t.F ROMS/Nonlinear/step3d_uv.F ROMS/Nonlinear/step_floats.F ROMS/Nonlinear/t3dbc_im.F ROMS/Nonlinear/t3dmix.F ROMS/Nonlinear/tkebc_im.F ROMS/Nonlinear/u2dbc_im.F ROMS/Nonlinear/u3dbc_im.F ROMS/Nonlinear/uv3dmix.F ROMS/Nonlinear/v2dbc_im.F ROMS/Nonlinear/v3dbc_im.F ROMS/Nonlinear/wetdry.F ROMS/Nonlinear/wvelocity.F ROMS/Nonlinear/zetabc.F ROMS/Functionals/analytical.F ROMS/SeaIce/seaice.F ROMS/Utility/abort.F ROMS/Utility/back_cost.F ROMS/Utility/cgradient.F ROMS/Utility/checkadj.F ROMS/Utility/checkdefs.F ROMS/Utility/checkerror.F ROMS/Utility/checkvars.F ROMS/Utility/close_io.F ROMS/Utility/congrad.F ROMS/Utility/cost_grad.F ROMS/Utility/def_avg.F ROMS/Utility/def_diags.F ROMS/Utility/def_dim.F ROMS/Utility/def_error.F ROMS/Utility/def_floats.F ROMS/Utility/def_gst.F ROMS/Utility/def_hessian.F ROMS/Utility/def_his.F ROMS/Utility/def_impulse.F ROMS/Utility/def_info.F ROMS/Utility/def_ini.F ROMS/Utility/def_lanczos.F ROMS/Utility/def_mod.F ROMS/Utility/def_norm.F ROMS/Utility/def_rst.F ROMS/Utility/def_station.F ROMS/Utility/def_tides.F ROMS/Utility/def_var.F ROMS/Utility/distribute.F ROMS/Utility/dotproduct.F ROMS/Utility/extract_obs.F ROMS/Utility/extract_sta.F ROMS/Utility/frc_weak.F ROMS/Utility/gasdev.F ROMS/Utility/get_2dfld.F ROMS/Utility/get_2dfldr.F ROMS/Utility/get_3dfld.F ROMS/Utility/get_3dfldr.F ROMS/Utility/get_bounds.F ROMS/Utility/get_cycle.F ROMS/Utility/get_date.F ROMS/Utility/get_grid.F ROMS/Utility/get_gst.F ROMS/Utility/get_ngfld.F ROMS/Utility/get_ngfldr.F ROMS/Utility/get_state.F ROMS/Utility/get_varcoords.F ROMS/Utility/grid_coords.F ROMS/Utility/ini_adjust.F ROMS/Utility/ini_lanczos.F ROMS/Utility/inp_par.F ROMS/Utility/interpolate.F ROMS/Utility/lubksb.F ROMS/Utility/ludcmp.F ROMS/Utility/metrics.F ROMS/Utility/mp_exchange.F ROMS/Utility/mp_routines.F ROMS/Utility/nf_fread2d_bry.F ROMS/Utility/nf_fread2d.F ROMS/Utility/nf_fread3d_bry.F ROMS/Utility/nf_fread3d.F ROMS/Utility/nf_fread4d.F ROMS/Utility/nf_fwrite2d_bry.F ROMS/Utility/nf_fwrite2d.F ROMS/Utility/nf_fwrite3d_bry.F ROMS/Utility/nf_fwrite3d.F ROMS/Utility/nf_fwrite4d.F ROMS/Utility/normalization.F ROMS/Utility/nrutil.F ROMS/Utility/obs_cost.F ROMS/Utility/obs_depth.F ROMS/Utility/obs_initial.F ROMS/Utility/obs_read.F ROMS/Utility/obs_write.F ROMS/Utility/oi_update.F ROMS/Utility/packing.F ROMS/Utility/posterior.F ROMS/Utility/posterior_var.F ROMS/Utility/ran1.F ROMS/Utility/random_ic.F ROMS/Utility/ran_state.F ROMS/Utility/regrid.F ROMS/Utility/rep_matrix.F ROMS/Utility/set_2dfld.F ROMS/Utility/set_2dfldr.F ROMS/Utility/set_3dfld.F ROMS/Utility/set_3dfldr.F ROMS/Utility/set_diags.F ROMS/Utility/set_ngfld.F ROMS/Utility/set_ngfldr.F ROMS/Utility/set_scoord.F ROMS/Utility/set_weights.F ROMS/Utility/shapiro.F ROMS/Utility/state_addition.F ROMS/Utility/state_copy.F ROMS/Utility/state_dotprod.F ROMS/Utility/state_initialize.F ROMS/Utility/state_product.F ROMS/Utility/state_scale.F ROMS/Utility/stats_modobs.F ROMS/Utility/stiffness.F ROMS/Utility/strings.F ROMS/Utility/sum_grad.F ROMS/Utility/timers.F ROMS/Utility/utility.F ROMS/Utility/white_noise.F ROMS/Utility/wpoints.F ROMS/Utility/wrt_avg.F ROMS/Utility/wrt_diags.F ROMS/Utility/wrt_error.F ROMS/Utility/wrt_floats.F ROMS/Utility/wrt_gst.F ROMS/Utility/wrt_hessian.F ROMS/Utility/wrt_his.F ROMS/Utility/wrt_impulse.F ROMS/Utility/wrt_info.F ROMS/Utility/wrt_ini.F ROMS/Utility/wrt_rst.F ROMS/Utility/wrt_station.F ROMS/Utility/wrt_tides.F ROMS/Modules/mod_arrays.F ROMS/Modules/mod_average.F ROMS/Modules/mod_bbl.F ROMS/Modules/mod_biology.F ROMS/Modules/mod_boundary.F ROMS/Modules/mod_clima.F ROMS/Modules/mod_coupler.F ROMS/Modules/mod_coupling.F ROMS/Modules/mod_diags.F ROMS/Modules/mod_eclight.F ROMS/Modules/mod_eoscoef.F ROMS/Modules/mod_floats.F ROMS/Modules/mod_forces.F ROMS/Modules/mod_fourdvar.F ROMS/Modules/mod_grid.F ROMS/Modules/mod_iounits.F ROMS/Modules/mod_kinds.F ROMS/Modules/mod_mixing.F ROMS/Modules/mod_ncparam.F ROMS/Modules/mod_nesting.F ROMS/Modules/mod_netcdf.F ROMS/Modules/mod_obs.F ROMS/Modules/mod_ocean.F ROMS/Modules/mod_parallel.F ROMS/Modules/mod_param.F ROMS/Modules/mod_scalars.F ROMS/Modules/mod_sediment.F ROMS/Modules/mod_sources.F ROMS/Modules/mod_stepping.F ROMS/Modules/mod_storage.F ROMS/Modules/mod_strings.F ROMS/Modules/mod_tides.F Master/esmf_roms.F Master/master.F Master/ocean_control.F Master/ocean_coupler.F Master/propagator.F Master/roms_export.F Master/roms_import.F > Build/MakeDepend
/bin/sh: ./ROMS/Bin/sfmakedepend: Permission denied
make: *** [depend] Error 126
So is it not allowed to create that file for some reason? What would be causing that?
Thanks!
What do you get from:
   ls -l Build
   ls -ld Build
   ls -l ./ROMS/Bin/sfmakedepend
Then if all those look normal, how about:
  which perl
  perl --version
lteeter
#5 Unread post by lteeter »
$ ls -l Build
total 0
-rw-r--r-- 1 lteeter theory 0 Jun 20 14:55 MakeDepend
$ ls -ld Build
drwxr-xr-x 2 lteeter theory 4096 Jun 20 14:55 Build
[lteeter@wahad BioUPW]$ ls -l ./ROMS/Bin/sfmakedepend
-rw-r--r-- 1 lteeter theory 22054 Jun 8 10:53 ./ROMS/Bin/sfmakedepend
Should all of these be drwxr-xr-x ??
perl --version:
This is perl, v5.8.8 built for i386-linux-thread-multi
#6 Unread post by kate »
Yes, everything in that directory should have the execute permissions set.
lteeter
#7 Unread post by lteeter »
Should everything in the ROMS directory be executable?
#8 Unread post by kate »
Everything in the ROMS/Bin directory should be executable. All the directories in the whole tree should be executable, but the source files shouldn't be, nor the License nor Version.
lteeter
#9 Unread post by lteeter »
All right, all of the directories in ./ROMS are executable and all of the files in ./ROMS/Bin
using: $ make -f makefile_BaseRun depend
I get:
#10 Unread post by kate »
So it worked and created that file? Time to move on to:
lteeter
#11 Unread post by lteeter »
I'm still back to getting the same message:
#12 Unread post by kate »
Your Build directory has the correct permissions. I didn't see an error message from the "make depend" phase. Did it make the file and what's in it? Mine starts with stuff like:
Build/esmf_roms.o: cppdefs.h globaldefs.h upwelling.h
Build/esmf_roms.f90: cppdefs.h globaldefs.h upwelling.h
Build/esmf_roms.o: Build/distribute.o Build/mod_coupler.o Build/mod_forces.o
lteeter
#13 Unread post by lteeter »
It did make the file, and the first few lines look the same as yours. (When I run make depend, it makes the MakeDepend file non-executable and I have to go in and change that manually every time. Could that be somehow causing the problem?)
#14 Unread post by kate »
The MakeDepend file does not have to be executable. I'm not sure what's wrong now.
lteeter
#15 Unread post by lteeter »
All right, thanks a lot for your help anyways!
