My computer system is winxp sp2.
compiler is cvf 6.6
with matlab 6.5 and netcdf 3.6.1
however,i find out it is very difficult to use roms
with windows cvf.
Is there instruction of how to use roms in windows cvf?
thanks your reply
help!about system
We also use Windows XP Systems, with Compaq 6.6 compiler or Intel ifort 9.0x compiler, with the netcdf 3.6.1.
To use roms in cvf, you would have to use Projects/Settings and tell cvf to preprocess the F files using cpp, on the Link tab you need to provide path to netcdf libraries. (it has been a while since I have used this).
Instead of using the Compaq Vis Fortran environment, we typically use Cygwin. Cygwin is a Unix emulating environment desgined for use on PC's. It is freely downloadable, do a google search for Cygwin, or Cygwin-X. ROMS releases have Compiler files for Cygwin-df and Cygwin-ifort.
Of the 2 options, I have found it easier to use Cygwin.
