using ANA_ICE and ANA_INITIAL
turuncu
#1 Unread post by turuncu »
I try to run ice code with only ANA_ICE cpp option (no ANA_INITIAL cpp flag is used) but model try to find the ice related variables in the initial condition netcdf file and gives following error,
 NLM: CHECKVARS - unable to find model variable: uice
I check the code and found that this error comes from '/ROMS/Utility/checkvars.F'. I also try to change cpp flag for ice model from "ifdef ICE_MODEL" to "ifdef ICE_MODEL && !defined ANA_ICE" but problem still continues. Do you have any idea to fix it?
Regards,
--ufuk
Re: using ANA_ICE and ANA_INITIAL
Try this syntax:
# if defined ICE_MODEL || !defined ANA_ICE
You will have to make the same change to get_state.F. Clearly, this isn't a case I tried, so let me know if that isn't the full fix.
turuncu
#3 Unread post by turuncu »
Thanks Kate. I tried your fix but it gives error in the compile time and i changed it like,
# if defined ICE_MODEL && !defined ANA_ICE
and it seems working.
Thanks again,
--ufuk
Yes, right you are.
