roms compiling problem with ifort
jihene
Location: Institut Préparatoire aux études d'ingénieurs de T
#1 Unread post by jihene »
Hi everyone
I just got a compiling problem with newest ROMS version (version 607) using ifort compiler. I ve been using the 519 version before and everything is fine. Does anybody meet the same problem or help me out. Here is the error msg.
ar: creating Build/libUTIL.a
ar: Build/abort.o: No such file or directory
make: *** [Build/libUTIL.a] Error 1
Re: roms compiling problem with ifort
Is there more to it? Why don't you have an abort.o? Do you have a Build/abort.f90? Was there trouble compiling it?
jihene
#3 Unread post by jihene »
Thanks Kate for your reply,
Yes I have the abord.f90 under the Build directory, but not the abort.o...You will find the content of the file bellow.
Thank you again for your help
Jihene
SUBROUTINE abort (status)
!svn $Id: abort.F 585 2012-01-03 18:44:28Z arango $
!================================================== Hernan G. Arango ===
! Copyright (c) 2002-2012 The ROMS/TOMS Group !
! Licensed under a MIT/X style license !
! See License_ROMS.txt !
! This subroutine terminates execution after flushing all buffers and !
! closing IO files. !
USE ocean_control_mod, ONLY : ROMS_finalize
implicit none
! Imported variable declarations.
integer, intent(in) :: status
! Terminate execution due to fatal error.
! Finalize ROMS component.
CALL ROMS_finalize
! Stop execution.
STOP
END SUBROUTINE abort
That's what my abort.f90 looks like too. Why doesn't yours compile? Mine does:
delta.arsc.edu 357% make Build/abort.o
makefile:234: INCLUDING FILE Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
cd Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math abort.f90
delta.arsc.edu 358%
(no error here)
tony1230
#5 Unread post by tony1230 »
hi jihene,
can you compile all the Roms versions older than 607 with the same ifort compiler ?
steve
jihene
#6 Unread post by jihene »
yes I compiled some previous versions of roms with the same compiler...I've no response for you kate!!really I don't understand where is the problem!!
#7 Unread post by arango »
Use the build script and select any of the test case in the test repository to see if you have the same problem. Avoid editing the makefile.
ibnode
#8 Unread post by ibnode »
hi jihene,
it seems you did not compile the "abort.f90" successfully. you should check the compiling log file and find out the exact failing point.
Ibnode
jihene
#9 Unread post by jihene »
Thanks I will try an other test!
