Run error: Subscript #2 of the array AKT_BAK has value 1
Pysh
#1 Unread post by Pysh »
Hi!
I tried to run ROMS application for Caspian sea. I am beginner. The model not runs with the message
forrtl: severe (408): fort: (2): Subscript #2 of the array AKT_BAK has value 1 which is greater than the upper bound of 0
This message arises when in configuration file (casp.h) there are
#undef MY25_MIXING
#undef LMD_MIXING
#define GLS_MIXING
(as in users/include/adria02.h)
and in input file (casp.in) there is line
AKT_BAK = 1.0d-06 1.0d-06
If I not include into casp.h these lines
(#undef MY25_MIXING
#undef LMD_MIXING
#define GLS_MIXING
#endif)
and by default model configuration has line
model run successfully with the same input file, but results are not good for me
I can't find this message in documentation and in the ROMS code.
Where is my mistake? Thanks
Re: Run error: Subscript #2 of the array AKT_BAK has value 1
First, you need to see how Akt_bak is dimensioned. I see:
ROMS/Modules/mod_scalars.F:      allocate ( Akt_bak(MT,Ngrids) )
so the second index is Ngrids. Your value of Ngrids must have been zero. In some versions of ROMS, the value comes from the makefile while in others, it comes from ocean.in. Did you perhaps update ROMS without updating the ocean.in file you are using?
Pysh
#3 Unread post by Pysh »
Thank you, Kate
In casp.in and in ocea.in value NGRIDS = 1. How it can be equal zero I'll try to undestand. Now I don't see it in makefile
I have the version of ROMS 580 (2011-11-28) The ocean.in is also from this version.
Regards,
Boris
The latest ROMS won't let you omit Ngrids:
 READ_PHYPAR - could not find input parameter: Ngrids
               in ROMS standard input script.
               Add "Ngrids" keyword before grid dimension (Lm, Mm).
Pysh
#5 Unread post by Pysh »
Kate,
Ok, I need update ROMS.
Many thanks for the help.
Pysh
#6 Unread post by Pysh »
Kate,
I'v updated the version of ROMS. The model run without problems.
Boris
