To whom it may concern:
I wonder if the *h file that I have could be modified to give me free-surface. It is driven by barotropic tides in the yellow sea but even though I apply tides, the results from the fortran plot programs do not seem to provide a variation of vater surface elevation. Below is my cdw.h ... I would appreciate your help.
Rafael
#define SPLINES
#define GLS_MIXING /* use if Generic Length-Scale mixing */
#define N2S2_HORAVG
#define KANTHA_CLAYSON
#define MIX_S_UV /* use if mixing along constant S-surfaces */
#define MIX_S_TS /* use if mixing along constant S-surfaces */
#define RAMP_TIDES
#define SSH_TIDES
#define UV_TIDES
#define NORTH_FSCHAPMAN
#define NORTH_M2FLATHER
#define SOUTH_FSCHAPMAN
#define SOUTH_M2FLATHER
#define EAST_FSCHAPMAN
#define EAST_M2FLATHER
#define WEST_FSCHAPMAN
#define WEST_M2FLATHER
#define ANA_INITIAL
#define ANA_FSOBC
#define ANA_M2OBC
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_SRFLUX
/* Lateral boundary conditions*/
/* #define EAST_FSGRADIENT /* use if free-surface radiation condition */
#define EAST_M3GRADIENT /* use if 3D momentum radiation condition */
#define EAST_KGRADIENT /* use if TKE fields radiation condition */
/* #define WEST_FSGRADIENT /* use if free-surface radiation condition */
#define WEST_M3GRADIENT /* use if 3D momentum radiation condition */
#define WEST_KGRADIENT /* use if TKE fields radiation condition */
/* #define NORTH_FSGRADIENT /* use if free-surface radiation condition */
#define NORTH_M3GRADIENT /* use if 3D momentum radiation condition */
#define NORTH_KGRADIENT /* use if TKE fields radiation condition */
/* #define SOUTH_FSGRADIENT /* use if free-surface radiation condition */
#define SOUTH_M3GRADIENT /* use if 3D momentum radiation condition */
#define SOUTH_KGRADIENT /* use if TKE fields radiation condition */
free surface
Re: free surface
I don't immediately see why you wouldn't get tides from this. Have you tried turning off the TIDES_RAMP? Where are you getting your tides from? Have you checked that file?
Re: free surface
Kate,
I do provide tides and they seem to work fine, but when I plot (using the fortran plot package or any other) I do not see variation of my water surface elevation, I see the elevation set at -0.5 m, which is the non-zero initial water surface that I was told ROMS accepts (do not take zero).
Is this a problem of plotting?
thanks
Rafael
thanks
Rafael
Re: free surface
I use ncview for a quick and dirty look at what's happening in the output.
ROMS can have a zero zeta as initial conditions. What can't be zero is zeta+depth (total water column depth).
