[SOLVED] netcdf configure using gfortran
sbergman
Location: Dept of Environmental Affairs - SA Governemt (& Oceanography SA)
#1 Unread post by sbergman »
I'm currently having trouble getting the upwelling test case to compile. I've successfully compiled and ran this case on another PC, so I'm confident that the error isnt related to the build.bash file.
I've read somewhere that it may be related to when I ran ./configure after installing latest version of netcdf.
I used
./configure --prefix=/home/username/local
but understand I may have needed to pass some more arguments to get it to configure with the gfortran compiler I use for ROMS.
Can someone here perhaps help me out with the correct ./configure command so I can reinstall netcdf ?
Re: netcdf configure using gfortran
As ever, it depends. Here's what I used last (on Linux):
configure FC=gfortran F77=gfortran F90=gfortran CXX=g++ --prefix=/u1/uaf/kate --enable-netcdf4 --enable-shared --with-hdf5=/u1/uaf/kate
m.hadfield
kate wrote:As ever, it depends. Here's what I used last (on Linux):
With the latest release of netCDF-4 (4.1.3) you don't use "--with-hdf5" to specify the location of the HDF5 libraries, you use CPPFLAGS and LDFLAGS. Also, I don't think F77 and F90 are required (or possibly even allowed) with this version. The above command would become
configure FC=gfortran CXX=g++ CPPFLAGS=-I/u1/uaf/kate/include LDFLAGS=-L/u1/uaf/kate/lib --prefix=/u1/uaf/kate --enable-netcdf4 --enable-shared
Or maybe "LDFLAGS=-L/u1/uaf/kate/lib64" if that's where the HDF5 libraries are installed.
To the original poster, I suggest you do use 4.1.3, as the netCDF developers have put a lot of work into cleaning up the build process and the operation of the nc-config script.
Thanks, Mark, my last build was way back at 4.1.1.
m.hadfield
kate wrote:Thanks, Mark, my last build was way back at 4.1.1.
Ancient history. :wink:
sbergman
#6 Unread post by sbergman »
Hi again, thanks to both of you I've got netcdf-4.1.3 installed.
For the record, I did a
make clean
and then a
./configure FC=gfortran CXX=g++ CPPFLAGS=-I/home/sbergman/local/include LDFLAGS=-L/home/sbergman/local/lib --prefix=/home/sbergman/local --disable-netcdf-4 --enable-shared
and then a
make check install
Note the:
--disable-netcdf-4
something went wrong if I enabled this. I didnt figure out why but it seems to work if I disable this option.
However when I compile the upwelling example, I still get underfined reference errors to files / routines with the double-underscore. The end of the error messages look like this
mod_netcdf.f90:(.text+0x11474): undefined reference to `__netcdf_MOD_nf90_get_var_1d_eightbytereal'
mod_netcdf.f90:(.text+0x11925): undefined reference to `__netcdf_MOD_nf90_get_var_1d_eightbytereal'
/home/sbergman/MyROMSProjects/Upwelling/Build/libMODS.a(mod_netcdf.o): In function `T.2871':
mod_netcdf.f90:(.text+0x11a42): undefined reference to `__netcdf_MOD_nf90_inq_varid'
mod_netcdf.f90:(.text+0x11a8a): undefined reference to `__netcdf_MOD_nf90_get_var_eightbytereal'
/home/sbergman/MyROMSProjects/Upwelling/Build/libMODS.a(mod_netcdf.o): In function `__mod_netcdf_MOD_netcdf_check_dim':
mod_netcdf.f90:(.text+0x138b6): undefined reference to `__netcdf_MOD_nf90_inquire'
mod_netcdf.f90:(.text+0x1396a): undefined reference to `__netcdf_MOD_nf90_inquire_dimension'
make: *** [/home/sbergman/MyROMSProjects/Upwelling/oceanS] Error 1
If you have any further suggestions, please let me know.
Regards,
- S
#7 Unread post by kate »
See if this is helpful. It could be a "-fno-second-underscore" kind of answer or the -lnetcdff issue.
m.hadfield
Hi sbergman
Have a look at the command that triggered those errors in building ROMS--post it here if you want. Does the linker command line have the options you expect? I would expect it to end with "-lnetcdff -lnetcdf". does it?
I don't think you need to worry about "-fno-second-underscore" or any of the other GCC options relating to code-generation conventions. (I think the two leading underscores in the undefined references are just part of the name-mangling for subroutines in the Fortran 90 interface and not related to the old G77-style name mangling, which added trailing underscores--either 1 or 2 depending on the day of the week or something. All ancient history now, I hope.)
The fact that you had to disable netcdf-4 in building netCDF shouldn't be a problem for now. It just means you have a netCDF-4 library that supports only the netCDF-3 interface. ROMS should be satisfied with that, until you try to use netCDF-4 output features. However it does suggest there was something wrong with these arguments in the configure command:
They are supposed to indicate where HDF5 is installed and the fact you couldn't build with --enable-netcdf-4 suggests this wasn't successful. Or some other problem.
PS: You did activate USE_NETCDF4 when building ROMS, didn't you?
sbergman
#9 Unread post by sbergman »
Hi again. Thanks for the help so far.
I've got
#export USE_NETCDF4=on            # compile with NetCDF-4 library
in my build.bash file. Am I correct in saying that its commented out cos I configured netcdf with the --disable-netcdf4 option? (and it's like that on the working pc...)
I tried doing a ./build.bash >> compilelog.txt and searched through that txt file for any clues.
The last line (where I assume) things went awry looks like this:
/usr/bin/gfortran -frepack-arrays -O3 -ffast-math  /home/sbergman/MyROMSProjects/Upwelling/Build/esmf_roms.o /home/sbergman/MyROMSProjects/Upwelling/Build/master.o /home/sbergman/MyROMSProjects/Upwelling/Build/ocean_control.o /home/sbergman/MyROMSProjects/Upwelling/Build/ocean_coupler.o /home/sbergman/MyROMSProjects/Upwelling/Build/propagator.o /home/sbergman/MyROMSProjects/Upwelling/Build/roms_export.o /home/sbergman/MyROMSProjects/Upwelling/Build/roms_import.o -o /home/sbergman/MyROMSProjects/Upwelling/oceanS /home/sbergman/MyROMSProjects/Upwelling/Build/libUTIL.a /home/sbergman/MyROMSProjects/Upwelling/Build/libNLM.a /home/sbergman/MyROMSProjects/Upwelling/Build/libNLM_bio.a /home/sbergman/MyROMSProjects/Upwelling/Build/libNLM_sed.a /home/sbergman/MyROMSProjects/Upwelling/Build/libANA.a /home/sbergman/MyROMSProjects/Upwelling/Build/libUTIL.a /home/sbergman/MyROMSProjects/Upwelling/Build/libMODS.a -L/home/sbergman/local/lib -lnetcdf
It looks like it was missing the -lnetcdff
I followed through kate's links, through the FAQ and ended up editing the file ~/ROMS/src/Compilers/Linux-gfortran.mk (on line 51 in my case) to
LIBS := -L$(NETCDF_LIBDIR) -lnetcdff -lnetcdf
while there I also noticed that it was pointing to
    NETCDF_INCDIR ?= /usr/local/include
    NETCDF_LIBDIR ?= /usr/local/lib
and I changed this to where my lib and include should be (according to my netcdf configure command).
Good news is that it compiled, but bad news is that I now get a runtime error which says:
./oceanS: error while loading shared libraries: libnetcdff.so.5: cannot open shared object file: No such file or directory
I've tried reinstalling netcdf and putting everything in /usr/local/.... so I undid those extra changes to Linux-gfortran.mk but the problem still arises.
I looked for the libnetcdff.so.5 in the /usr/local/lib folder and found that it links to a libnetcdff.so.5.1.0 in the same folder - both are definitely there.
Any further suggestions?
- S
#10 Unread post by kate »
sbergman wrote:I've got
No, you want to have USE_NETCDF4 on so that you pick up the nc-config during the build - it knows to include -lnetcdff for you.
What is in your LD_LIBRARY_PATH environment variable? Are you running on the command line or from a batch script? Does the batch script have the right environment to find /usr/local?
sbergman
#11 Unread post by sbergman »
I think you guys have solved the problem:
There was no reference to LD_LIBRARY_PATH in my ~/.bashrc so I added the following:
LD_LIBRARY_PATH=/home/sbergman/local/lib
export LD_LIBRARY_PATH
and things fell into place. So the upwelling example is running at the moment.
Mind you, since yesterday I've also installed zlib, hdf and rebuilt netcdf to include those options, thinking that my initial problem was caused, for some reason, by NOT enabling netcdf4. Followed that entire process through and then found out about editing the .bashrc file. At least the spin-off advantage is that I've got netcdf-4 working now.
A side-issue is that I had a confusing problem after installing zlib - I got a segmentation fault on synaptic and after rebooting the pc, no login prompt would appear though the xserver would start. Turns out that zlib conflicts with gdm. I uninstalled zlib and reinstalled it somewhere under my /home directory (ie: ./configure --prefix=/home/sbergman/local/) hoping that it'd avoid the conflict... I guess it did.
Thanks for the assistance!
- S
m.hadfield
Re: [SOLVED] netcdf configure using gfortran
#12 Unread post by m.hadfield »
That zlib issue is an odd one! I guess it shows that life isn't meant to be easy. I'm glad you got it sorted out. :D
