I could not compile Netcdf. I have tried both netcdf 3.6.2 (as described in the wiki) and netcdf 4.1.3 (latest). Essentially, the 'makefile' was not created after I typed:
CC=gcc FC=gfortran-4 F77=gfortran-4 CPPFLAGS=-DpgiFortran ./configure
Apparently, the compilation went well without errors. But the makefile didn't come out. So I couldn't proceed with 'Make Check' and 'Make Install'.
Any prompt help would be very much appreciated!
Perhaps it helps if I paste the configure.log below:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by netCDF configure 3.6.2, which was
generated by GNU Autoconf 2.61. Invocation command line was
$ ./configure
## Platform. ##
hostname = simonhcw-pc
uname -m = i686
uname -r = 1.7.9(0.237/5/3)
uname -s = CYGWIN_NT-6.1
uname -v = 2011-03-29 10:10
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /cygdrive/c/Program Files/swan
PATH: /cygdrive/c/Program Files/Common Files/Microsoft Shared/Windows Live
PATH: /cygdrive/c/Program Files/MiKTeX 2.7/miktex/bin
PATH: /cygdrive/c/Windows/system32
PATH: /cygdrive/c/Windows/System32/Wbem
PATH: /cygdrive/c/Program Files/Common Files/Roxio Shared/10.0/DLLShared
PATH: /cygdrive/c/Program Files/Common Files/Roxio Shared/DLLShared
PATH: /cygdrive/c/Program Files/Softex/OmniPass
PATH: /cygdrive/c/Windows/System32/WindowsPowerShell/v1.0
PATH: /cygdrive/c/Program Files/MATLAB/R2009a Student/bin
PATH: /cygdrive/c/Program Files/MATLAB/R2009a Student/bin/win32
PATH: /cygdrive/c/Program Files/Intel/WiFi/bin
PATH: /cygdrive/c/Program Files/Common Files/Intel/WirelessCommon
PATH: /cygdrive/c/Program Files/Common Files/Thunder Network/KanKan/Codecs
PATH: /cygdrive/c/Program Files/QuickTime/QTSystem
PATH: /cygdrive/c/Program Files/VanDyke Software/Clients
PATH: /cygdrive/c/Program Files/Windows Live/Shared
PATH: /cygdrive/c/strawberry/c/bin
PATH: /cygdrive/c/strawberry/perl/site/bin
PATH: /cygdrive/c/strawberry/perl/bin
PATH: /cygdrive/c/Users/simonhcw/Downloads/g95/bin
## Core tests. ##
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
gcc (GCC) 4.5.0
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure
configure
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-pc-cygwin/4.5.0/lto-wrapper.exe
Target: i686-pc-cygwin
Configured with: /gnu/gcc/releases/respins/4.5.0-1/gcc4-4.5.0-1/src/gcc-4.5.0/configure --srcdir=/gnu/gcc/releases/respins/4.5.0-1/gcc4-4.5.0-1/src/gcc-4.5.0 --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib --datadir=/usr/share --localstatedir=/var --sysconfdir=/etc --datarootdir=/usr/share --docdir=/usr/share/doc/gcc4 --datadir=/usr/share --infodir=/usr/share/info --mandir=/usr/share/man -v --with-gmp=/usr --with-mpfr=/usr --enable-bootstrap --enable-version-specific-runtime-libs --libexecdir=/usr/lib --enable-static --enable-shared --enable-shared-libgcc --disable-__cxa_atexit --with-gnu-ld --with-gnu-as --with-dwarf2 --disable-sjlj-exceptions --enable-languages=ada,c,c++,fortran,java,lto,objc,obj-c++ --enable-graphite --enable-lto --enable-java-awt=gtk --disable-symvers --enable-libjava --program-suffix=-4 --enable-libgomp --enable-libssp --enable-libada --enable-threads=posix --with-arch=i686 --with-tune=generic --enable-libgcj-sublibs CC=gcc-4 CXX=g++-4 CC_FOR_TARGET=gcc-4 CXX_FOR_TARGET=g++-4 GNATMAKE_FOR_TARGET=gnatmake GNATBIND_FOR_TARGET=gnatbind --with-ecj-jar=/usr/share/java/ecj.jar
Thread model: posix
gcc version 4.5.0 (GCC)
configure
configure
gcc: '-V' option must have argument
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure:4042: result: gcc3
configure:4060: checking whether gcc and cc understand -c and -o together
configure:4095: gcc -c conftest.c -o conftest2.o >&5
configure:4098: $? = 0
configure:4104: gcc -c conftest.c -o conftest2.o >&5
configure:4107: $? = 0
configure:4118: cc -c conftest.c >&5
configure:4121: $? = 0
configure:4129: cc -c conftest.c -o conftest2.o >&5
configure:4132: $? = 0
configure:4138: cc -c conftest.c -o conftest2.o >&5
configure:4141: $? = 0
configure:4159: result: yes
configure:4185: checking for an ANSI C-conforming const
configure:4260: gcc -c -g -O2 -DpgiFortran conftest.c >&5
configure:4266: $? = 0
configure:4281: result: yes
configure:4312: finding Fortran compiler (will not be used if Fortran API is not desired)
configure:4702: checking for Fortran compiler version
configure:4709: gfortran-4 --version >&5
GNU Fortran (GCC) 4.3.4 20090804 (release) 1
Copyright (C) 2008 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:4712: $? = 0
configure:4719: gfortran-4 -v >&5
Configured with: /gnu/gcc/releases/respins/4.3.4-4/gcc4-4.3.4-4/src/gcc-4.3.4/configure --srcdir=/gnu/gcc/releases/respins/4.3.4-4/gcc4-4.3.4-4/src/gcc-4.3.4 --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib --datadir=/usr/share --localstatedir=/var --sysconfdir=/etc --infodir=/usr/share/info --mandir=/usr/share/man -C --datadir=/usr/share --infodir=/usr/share/info --mandir=/usr/share/man -v --with-gmp=/usr --with-mpfr=/usr --enable-bootstrap --enable-version-specific-runtime-libs --with-slibdir=/usr/bin --libexecdir=/usr/lib --enable-static --enable-shared --enable-shared-libgcc --disable-__cxa_atexit --with-gnu-ld --with-gnu-as --with-dwarf2 --disable-sjlj-exceptions --enable-languages=ada,c,c++,fortran,java,objc,obj-c++ --disable-symvers --enable-libjava --program-suffix=-4 --enable-libgomp --enable-libssp --enable-libada --enable-threads=posix --with-arch=i686 --with-tune=generic --enable-libgcj-sublibs CC=gcc-4 CXX=g++-4 CC_FOR_TARGET=gcc-4 CXX_FOR_TARGET=g++-4 GNATMAKE_FOR_TARGET=gnatmake GNATBIND_FOR_TARGET=gnatbind --with-ecj-jar=/usr/share/java/ecj.jar
Thread model: posix
gcc version 4.3.4 20090804 (release) 1 (GCC)
configure:4722: $? = 0
configure:4729: gfortran-4 -V >&5
gfortran-4: '-V' option must have argument
configure:4732: $? = 1
configure:4740: checking whether we are using the GNU Fortran compiler
configure:4759: gfortran-4 -c conftest.F >&5
gfortran-4: error trying to exec 'cc1': execvp: No such file or directory
configure:4765: $? = 1
configure: failed program was:
| program main
| #ifndef __GNUC__
| choke me
| #endif
| end
configure:4782: result: no
configure:4788: checking whether gfortran-4 accepts -g
configure:4805: gfortran-4 -c -g conftest.f >&5
configure:4811: $? = 0
configure:4827: result: yes
configure:4977: checking for Fortran 77 compiler version
configure:4984: gfortran-4 --version >&5
configure:4987: $? = 0
configure:4994: gfortran-4 -v >&5
Thread model: posix
configure:4997: $? = 0
configure:5004: gfortran-4 -V >&5
configure:5007: $? = 1
configure:5015: checking whether we are using the GNU Fortran 77 compiler
configure:5034: gfortran-4 -c conftest.F >&5
configure:5040: $? = 1
| program main
| #ifndef __GNUC__
| choke me
| #endif
| end
configure:5057: result: no
configure:5063: checking whether gfortran-4 accepts -g
configure:5080: gfortran-4 -c -g conftest.f >&5
configure:5086: $? = 0
configure:5102: result: yes
configure:5146: setting up Fortran 90
configure:5165: checking for Fortran flag to compile .f90 files
configure:5187: gfortran-4 -c -g conftest.f90 >&5
configure:5193: $? = 0
configure:5212: result: none
configure:5242: checking fortran 90 modules inclusion flag
configure:5273: gfortran-4 -c -g conftest.f90 >&5
configure:5279: $? = 0
configure:5312: gfortran-4 -c -g -Itmpdir_0 conftest.f90 >&5
configure:5318: $? = 0
configure:5349: result: -I
configure:5361: checking if Fortran compiler can handle Fortran-90
configure:5369: gfortran-4 conftest.f90
/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../../../i686-pc-cygwin/bin/ld: cannot find crtbegin.o: No such file or directory
/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../../../i686-pc-cygwin/bin/ld: cannot find -lgcc_s
/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../../../i686-pc-cygwin/bin/ld: cannot find crtend.o: No such file or directory
configure:5372: $? = 1
configure:5386: result: no
configure:5389: WARNING: No F90 compiler found. F90 API will not be built.
configure:5395: finding C++ compiler (will not be used if C++ API is not desired)
configure:5462: checking for g++
configure:5478: found /usr/bin/g++
configure:5489: result: g++
configure:5520: checking for C++ compiler version
configure:5527: g++ --version >&5
g++ (GCC) 3.4.4 (cygming special, gdc 0.12, using dmd 0.125)
Copyright (C) 2004 Free Software Foundation, Inc.
configure:5530: $? = 0
configure:5537: g++ -v >&5
Reading specs from /usr/lib/gcc/i686-pc-cygwin/3.4.4/specs
Configured with: /usr/build/package/orig/test.respin/gcc-3.4.4-3/configure --verbose --prefix=/usr --exec-prefix=/usr --sysconfdir=/etc --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --enable-languages=c,ada,c++,d,f77,pascal,java,objc --enable-nls --without-included-gettext --enable-version-specific-runtime-libs --without-x --enable-libgcj --disable-java-awt --with-system-zlib --enable-interpreter --disable-libgcj-debug --enable-threads=posix --enable-java-gc=boehm --disable-win32-registry --enable-sjlj-exceptions --enable-hash-synchronization --enable-libstdcxx-debug
Thread model: posix
gcc version 3.4.4 (cygming special, gdc 0.12, using dmd 0.125)
configure:5540: $? = 0
configure:5547: g++ -V >&5
g++: `-V' option must have argument
configure:5550: $? = 1
configure:5553: checking whether we are using the GNU C++ compiler
configure:5582: g++ -c -DpgiFortran conftest.cpp >&5
configure:5588: $? = 0
configure:5605: result: yes
configure:5610: checking whether g++ accepts -g
configure:5640: g++ -c -g -DpgiFortran conftest.cpp >&5
configure:5646: $? = 0
configure:5745: result: yes
configure:5770: checking dependency style of g++
configure:5860: result: gcc3
configure:5992: checking for as
configure:6008: found /usr/bin/as
configure:6019: result: as
configure:6088: checking for dlltool
configure:6104: found /usr/bin/dlltool
configure:6115: result: dlltool
configure:6184: checking for objdump
configure:6200: found /usr/bin/objdump
configure:6211: result: objdump
configure:6366: checking for a sed that does not truncate output
configure:6445: result: /usr/bin/sed
configure:6463: checking for grep that handles long lines and -e
configure:6537: result: /usr/bin/grep
configure:6542: checking for egrep
configure:6620: result: /usr/bin/grep -E
configure:6625: checking for fgrep
configure:6703: result: /usr/bin/grep -F
configure:6738: checking for ld used by gcc
configure:6805: result: /usr/i686-pc-cygwin/bin/ld.exe
configure:6814: checking if the linker (/usr/i686-pc-cygwin/bin/ld.exe) is GNU ld
configure:6829: result: yes
configure:6842: checking for BSD- or MS-compatible name lister (nm)
configure:6891: result: /usr/bin/nm -B
configure:7013: checking the name lister (/usr/bin/nm -B) interface
configure:7020: gcc -c -g -O2 -DpgiFortran conftest.c >&5
configure:7023: /usr/bin/nm -B "conftest.o"
configure:7026: output
00000000 b .bss
00000000 d .data
00000000 N .debug_abbrev
00000000 N .debug_info
00000000 N .debug_line
00000000 N .debug_pubnames
00000000 t .text
00000000 B _some_variable
configure:7033: result: BSD nm
configure:7036: checking whether ln -s works
configure:7040: result: yes
configure:7048: checking the maximum length of command line arguments
configure:7162: result: 8192
configure:7180: checking whether the shell understands some XSI constructs
configure:7188: result: yes
configure:7192: checking whether the shell understands "+="
configure:7198: result: yes
configure:7233: checking for /usr/i686-pc-cygwin/bin/ld.exe option to reload object files
configure:7240: result: -r
configure:7267: checking how to recognise dependent libraries
configure:7451: result: file_magic ^x86 archive import|^x86 DLL
configure:7511: checking for ar
configure:7527: found /usr/bin/ar
configure:7538: result: ar
configure:7620: checking for strip
configure:7636: found /usr/bin/strip
configure:7647: result: strip
configure:7723: checking for ranlib
configure:7739: found /usr/bin/ranlib
configure:7750: result: ranlib
configure:7844: checking command to parse /usr/bin/nm -B output from gcc object
configure:7960: gcc -c -g -O2 -DpgiFortran conftest.c >&5
configure:7963: $? = 0
configure:7967: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' \> conftest.nm
configure:7970: $? = 0
cannot find nm_test_var in conftest.nm
configure:7967: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*_\([_A-Za-z][_A-Za-z0-9]*\)$/\1 _\2 \2/p' \> conftest.nm
configure:8024: gcc -o conftest.exe -g -O2 -DpgiFortran conftest.c conftstm.o >&5
configure:8027: $? = 0
configure:8065: result: ok
configure:8297: checking how to run the C preprocessor
configure:8337: gcc -E -DpgiFortran conftest.c
configure:8343: $? = 0
configure:8374: gcc -E -DpgiFortran conftest.c
conftest.c:12:28: fatal error: ac_nonexistent.h: No such file or directory
compilation terminated.
configure:8380: $? = 1
| /* confdefs.h. */
| #define PACKAGE_NAME "netCDF"
| #define PACKAGE_TARNAME "netcdf"
| #define PACKAGE_VERSION "3.6.2"
| #define PACKAGE_STRING "netCDF 3.6.2"
| #define PACKAGE_BUGREPORT "support@unidata.ucar.edu"
| #define PACKAGE "netcdf"
| #define VERSION "3.6.2"
| #define USE_EXTREME_NUMBERS 1
| #define TEMP_LARGE $TEMP_LARGE
| /* end confdefs.h. */
| #include <ac_nonexistent.h>
configure:8413: result: gcc -E
configure:8442: gcc -E -DpgiFortran conftest.c
configure:8448: $? = 0
configure:8479: gcc -E -DpgiFortran conftest.c
configure:8485: $? = 1
| /* confdefs.h. */
configure:8523: checking for ANSI C header files
configure:8553: gcc -c -g -O2 -DpgiFortran conftest.c >&5
configure:8559: $? = 0
configure:8658: gcc -o conftest.exe -g -O2 -DpgiFortran conftest.c >&5
configure:8661: $? = 0
configure:8667: ./conftest.exe
configure:8670: $? = 0
configure:8687: result: yes
configure:8711: checking for sys/types.h
configure:8732: gcc -c -g -O2 -DpgiFortran conftest.c >&5
configure:8738: $? = 0
configure:8754: result: yes
configure:8711: checking for sys/stat.h
configure:8711: checking for stdlib.h
configure:8711: checking for string.h
configure:8711: checking for memory.h
configure:8711: checking for strings.h
configure:8711: checking for inttypes.h
configure:8711: checking for stdint.h
configure:8711: checking for unistd.h
configure:8770: checking for dlfcn.h
configure:8791: gcc -c -g -O2 -DpgiFortran conftest.c >&5
configure:8797: $? = 0
configure:8813: result: yes
configure:8942: checking for C++ compiler version
configure:8949: g++ --version >&5
configure:8952: $? = 0
configure:8959: g++ -v >&5
Thread model: posix
configure:8962: $? = 0
configure:8969: g++ -V >&5
configure:8972: $? = 1
configure:8975: checking whether we are using the GNU C++ compiler
configure:9027: result: yes
configure:9032: checking whether g++ accepts -g
configure:9167: result: yes
configure:9192: checking dependency style of g++
configure:9282: result: gcc3
configure:9307: checking how to run the C++ preprocessor
configure:9343: g++ -E -DpgiFortran conftest.cpp
configure:9349: $? = 0
configure:9380: g++ -E -DpgiFortran conftest.cpp
conftest.cpp:23:28: ac_nonexistent.h: No such file or directory
configure:9386: $? = 1
| /* confdefs.h. */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
configure:9419: result: g++ -E
configure:9448: g++ -E -DpgiFortran conftest.cpp
configure:9454: $? = 0
configure:9485: g++ -E -DpgiFortran conftest.cpp
configure:9491: $? = 1
| /* confdefs.h. */
configure:9642: checking for Fortran 77 compiler version
configure:9649: gfortran-4 --version >&5
configure:9652: $? = 0
configure:9659: gfortran-4 -v >&5
Thread model: posix
configure:9662: $? = 0
configure:9669: gfortran-4 -V >&5
configure:9672: $? = 1
configure:9680: checking whether we are using the GNU Fortran 77 compiler
configure:9722: result: no
configure:9728: checking whether gfortran-4 accepts -g
configure:9767: result: yes
configure:9910: checking for Fortran compiler version
configure:9917: gfortran-4 --version >&5
configure:9920: $? = 0
configure:9927: gfortran-4 -v >&5
Thread model: posix
configure:9930: $? = 0
configure:9937: gfortran-4 -V >&5
configure:9940: $? = 1
configure:9948: checking whether we are using the GNU Fortran compiler
configure:9990: result: no
configure:9996: checking whether gfortran-4 accepts -g
configure
configure
configure
configure
configure
cc1: warning: command line option "-fno-rtti" is valid for C++/ObjC++ but not for C
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
configure
conftest.c: In function 'sub_':
conftest.c:4:3: warning: incompatible implicit declaration of built-in function 'exit'
configure
configure
configure
configure
configure
configure
## Cache variables. ##
ac_cv_build=i686-pc-cygwin
ac_cv_c_compiler_gnu=yes
ac_cv_c_const=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value=gcc
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=set
ac_cv_env_CPPFLAGS_value=-DpgiFortran
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=set
ac_cv_env_F77_value=gfortran-4
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=set
ac_cv_env_FC_value=gfortran-4
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_exeext=.exe
ac_cv_f77_compiler_gnu=no
ac_cv_fc_compiler_gnu=no
ac_cv_fc_srcext_f90=none
ac_cv_header_dlfcn_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_host=i686-pc-cygwin
ac_cv_objext=o
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_FGREP='/usr/bin/grep -F'
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_SED=/usr/bin/sed
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_NM='/usr/bin/nm -B'
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_AS=as
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_DLLTOOL=dlltool
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cc_gcc_c_o=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_f90_uppercase_mod=no
ac_cv_prog_fc_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_sys_file_offset_bits=no
ac_cv_sys_largefile_CC=no
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
lt_cv_file_magic_cmd=func_win32_libid
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/i686-pc-cygwin/bin/ld.exe
lt_cv_path_LDCXX=/usr/i686-pc-cygwin/bin/ld.exe
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_c_o_F77=yes
lt_cv_prog_compiler_c_o_FC=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*_\([_A-Za-z][_A-Za-z0-9]*\)$/\1 _\2 \2/p'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=8192
## Output variables. ##
ACLOCAL='${SHELL} /home/simonhcw/software/netcdf-3.6.2/missing --run aclocal-1.9'
ALLOCA=''
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/simonhcw/software/netcdf-3.6.2/missing --run tar'
AR='ar'
AS='as'
AUTOCONF='${SHELL} /home/simonhcw/software/netcdf-3.6.2/missing --run autoconf'
AUTOHEADER='${SHELL} /home/simonhcw/software/netcdf-3.6.2/missing --run autoheader'
AUTOMAKE='${SHELL} /home/simonhcw/software/netcdf-3.6.2/missing --run automake-1.9'
AWK='gawk'
BUILD_CXX_FALSE='#'
BUILD_CXX_TRUE=''
BUILD_C_FALSE='#'
BUILD_C_TRUE=''
BUILD_DLL_FALSE=''
BUILD_DLL_TRUE='#'
BUILD_EXAMPLES_FALSE='#'
BUILD_EXAMPLES_TRUE=''
BUILD_F77_FALSE='#'
BUILD_F77_TRUE=''
BUILD_F90_FALSE=''
BUILD_F90_TRUE='#'
BUILD_SEPARATE_FORTRAN_FALSE=''
BUILD_SEPARATE_FORTRAN_TRUE='#'
BUILD_SHARED_FALSE=''
BUILD_SHARED_TRUE='#'
BUILD_UTILITIES_FALSE='#'
BUILD_UTILITIES_TRUE=''
BUILD_V2_FALSE='#'
BUILD_V2_TRUE=''
CC='gcc'
CCDEPMODE='depmode=gcc3'
CFLAGS='-g -O2'
CPP='gcc -E'
CPPFLAGS='-DpgiFortran'
CXX='g++'
CXXCPP='g++ -E'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-g -O2'
CYGPATH_W='cygpath -w'
DEFS=''
DEPDIR='.deps'
DLLTOOL='dlltool'
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT='.exe'
F77='gfortran-4'
FC='gfortran-4'
FCFLAGS='-g'
FCFLAGS_f90=''
FFLAGS='-g'
FTPBINDIR=''
GREP='/usr/bin/grep'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_DOCS_FALSE=''
INSTALL_DOCS_TRUE='#'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
LARGE_FILE_TESTS_FALSE=''
LARGE_FILE_TESTS_TRUE='#'
LD='/usr/i686-pc-cygwin/bin/ld.exe'
LDFLAGS=''
LIBOBJS=''
LIBS=''
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LN_S='ln -s'
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/simonhcw/software/netcdf-3.6.2/missing --run makeinfo'
MAKEWHATIS_CMD=''
MOD_FLAG='-I'
NETCDF_C_LIB=''
NM='/usr/bin/nm -B'
NMFLAGS=''
OBJDUMP='objdump'
OBJEXT='o'
PACKAGE='netcdf'
PACKAGE_BUGREPORT='support@unidata.ucar.edu'
PACKAGE_NAME='netCDF'
PACKAGE_STRING='netCDF 3.6.2'
PACKAGE_TARNAME='netcdf'
PACKAGE_VERSION='3.6.2'
PATH_SEPARATOR=':'
RANLIB='ranlib'
SED='/usr/bin/sed'
SET_MAKE=''
SHAREEXT_DYLIB_FALSE=''
SHAREEXT_DYLIB_TRUE='#'
SHAREEXT_SL_FALSE=''
SHAREEXT_SL_TRUE='#'
SHELL='/bin/sh'
STRIP='strip'
TEST_F77_FALSE='#'
TEST_F77_TRUE=''
TEST_PARALLEL_FALSE=''
TEST_PARALLEL_TRUE=''
UPPER_CASE_MOD_FALSE=''
UPPER_CASE_MOD_TRUE=''
USE_FFIO_FALSE=''
USE_FFIO_TRUE='#'
USE_HDF5_DIR_FALSE=''
USE_HDF5_DIR_TRUE='#'
USE_NETCDF4_FALSE=''
USE_NETCDF4_TRUE='#'
USE_NETCDF_C_LIB_DIR_FALSE=''
USE_NETCDF_C_LIB_DIR_TRUE='#'
VERSION='3.6.2'
WHATIS=''
ac_ct_CC=''
ac_ct_CXX='g++'
ac_ct_DUMPBIN=''
ac_ct_F77=''
ac_ct_FC=''
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='i686-pc-cygwin'
build_alias=''
build_cpu='i686'
build_os='cygwin'
build_vendor='pc'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host='i686-pc-cygwin'
host_alias=''
host_cpu='i686'
host_os='cygwin'
host_vendor='pc'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='/home/simonhcw/software/netcdf-3.6.2/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
lt_ECHO='echo'
mandir='${datarootdir}/man'
mkdir_p='mkdir -p --'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
prog=''
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
#define LT_OBJDIR ".libs/"
#define NF_INT1_T byte
#define NF_INT2_T integer*2
configure: exit 1
