activating or enable sea-ice model ???
turuncu
#1 Unread post by turuncu »
How can i add the ice related variables (such as ice thickness, varinfo.dat has variable name "hice") into the history file. Is there any special preprocessor flag to enable sea ice model? I check the code but there is only one flag (ICE_SHELF) which seems not related with the output.
--ufuk
Re: activating or enable sea-ice model ???
Are you running the trunk code? It doesn't have sea ice. You instead need to ask Dave Robertson for access to my ice branch which has an example input file over in Apps/NEP.
turuncu
#3 Unread post by turuncu »
I am using latest tag (ROMS version 3.4). How can i contact with him?
--ufuk
He's the admin of this forum, or robertson@marine.rutgers.edu .
turuncu
#5 Unread post by turuncu »
I wrote to him but i could not get any response yet. Thanks,
--ufuk
#6 Unread post by kate »
Fixed now, right? Can you also see the ice section in this forum?
Seriously, I could be talked into putting my branch on github because these delays happen - that's life when one person holds the keys.
turuncu
#7 Unread post by turuncu »
Hi Kate,
Now, i am able to access the ice code and also ice model related section. I totally understand you, it is not easy to manage all of these things. I will try to setup and install it tomorrow. Thanks,
Regards,
--ufuk
