Bugs in adsen_ocean.h
hjsong
#1 Unread post by hjsong »
I would like to report some trivial bugs that I found in adsen_ocean.h after updating ROMS code to the most recent version.
First, I think the line 219 should be commented out because it is already declared in line 133.
Line 219 looks like
 10   FORMAT (' Process Information:',/)
And under the subroutine ROMS_run (after line 227), the local variable 'ng' is not declared.
So after line 245, this should be added as other subroutines.
!  Local variable declarations.
      integer :: ng
Well, that's it!
I am just amazed how much the ROMS has been improved!
Hajoon
Re: Bugs in adsen_ocean.h
#2 Unread post by arango »
Yes, thank you for reporting this problem. The code was cleaned a lot in version ROMS 3.5 and has a lot of nice new features. The nesting is complex and will require better grid generation tools in the future. We will address this issue when we get there.
