MCT and ARPACK
Suggest improvements/optimizations to the ROMS code.
mathieu
MCT and ARPACK
#1 Unread post by mathieu »
ROMS comes with included MCT and ARPACK libraries. What is the reason for that?
Is it for convenience so that we can compile it easily or were there some modifications to the code?
If so, what were those modifications?
Re: MCT and ARPACK
ROMS is a complex beast. The ocean-only forward model uses neither library, but the coupled wave model uses MCT and the adjoint package uses ARPACK.
Re: MCT and ARPACK
#3 Unread post by arango »
Yes, Users needing the ARPACK/PARPACK libraries in the adjoint-based algorithms need to use the provided libraries in the Lib/ARPACK directory. We had to make changes and additions to these libraries to allow check-pointing.
mathieu
Re: MCT and ARPACK
#4 Unread post by mathieu »
Ok, so ARPACK has been modified. But are those modifications documented?
Has MCT been modified as well? Will those modifications be included in current distribution of those softwares?
