QUESTION about ESMF_DIR variable in build.bash
dnavidad
#1 Unread post by dnavidad »
Hi everybody,
this is part of my build.bash.
I wonder about the role of ESMF_DIR in this part of the file, because really this path doesn't exist in my cluster, but i don't get any error about this when compiling.
thanks.
export USE_MY_LIBS=on #Changed
case "$FORT" in
ifort )
export ESMF_DIR=/opt/intelsoft/esmf-3.1.0
export ESMF_OS=Linux
export ESMF_COMPILER=ifort
export ESMF_BOPT=O
export ESMF_ABI=64
export ESMF_COMM=mpich
export ESMF_SITE=default
export MCT_INCDIR=/opt/netcdf/3.5.1-intel/include
export MCT_LIBDIR=/opt/netcdf/3.5.1-intel/lib
Re: QUESTION about ESMF_DIR variable in build.bash
ESMF is a coupling library. If you aren't using this library, then you don't have to have the correct path to it.
dnavidad
#3 Unread post by dnavidad »
thanks,
really i try to run the inlet test with swan and roms.
is it important to this case?
in any case i put the right path.
thanks.
I've never run coupled, but I thought the main coupling was done with MCT, not ESMF. Perhaps you have a choice.
dnavidad
#5 Unread post by dnavidad »
thanks.
