low sea level with wind forcing
flcastej
Location: Technical University of Cartagena,Murcia, Spain
#1 Unread post by flcastej »
I am trying to simulate a coastal lagoon, (max. depth=6m, area=170 mk2 ) only forcing with real wind data. I use the Bulk_fluxes, but comparing the ROMs data with the registred data for the same period simulated, I get smaller values with ROMs. Registered data is around 0.1 m sea level fluctuations (remove tide), and ROMs data maximum is about 0.01.
I am use this options:
#define TS_MPDATA
#define SPLINES
#define BULK_FLUXES
#define STATIONS
#define ATM_PRESS
#define UV_LOGDRAG
#define ANA_INITIAL
#define MY25_MIXING
#define KANTHA_CLAYSON
#define N2S2_HORAVG
I am using 16 sigma level.
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.015d0 ! m
Zos == 0.02d0 ! m
Someone could advise me about what i am doing wrong or where start to look for the problem?
Thanks a lot !!!
flcastej
Re: low sea level with wind forcing
#2 Unread post by flcastej »
After a lot of test done, messages in the forum read and a bit of luck, I has resolve my problem. I dont know if it ´s the right answer, but at the moment, I get the expected results.
With bulk fluxes, using the value of BLK_ZW =1 instead usual one BLK_ZW = 10.
BLK_ZW Height (m) of surface winds measurement. Usually, recorded
! at 10 m
