What I find is that, when plotting a cross-section of the temperature contours from the first history file (his_0001.nc), my isopycnals are not flat. Looking at the code, it appeared that the initial history file should be exactly the initial condition. However, upon plotting a comparison of the the two, this is not the case:
It looks like the model computes some diagnostics, such as KE, PE, volume, etc., but I didn't seem clear to me if any of the initial 3d fields are updated before the first output (esp. since KE is zero):
0 0 00:00:00 0.000000E+00 2.810623E+03 2.810623E+03 1.151972E+13
DEF_HIS - creating history file: his_0001.nc
WRT_HIS - wrote history fields (Index=1,1) into time record = 0001
