Question on subroutine netcdf_get_fvar from mod_netcdf.F
I have a small question regarding subroutine netcdf_get_fvar. This routine is called within get_ngfld.F around line 400 (SVN rev.491M, very recent) to obtain a one-dimensional array called 'A(:)', yet the 'start' and 'total' arguments each have two elements (as if A(:) was two-dimensional). It is this combination of 1-D and 2-D that confuses me, but I may be missing something trivial. Anyway, since 'A(:)' is 1-D, this call is transfered to subroutine netcdf_get_fvar_1d from module mod_netcdf.F. This particular routine tries to store the array 'total(:)' into a one-element array called 'Asize(1)' around line 1960, and this results in runtime error since size(total)=2 > size(Asize)=1.
I'm very curious about this; if someone understands I'd be very happy to know.
Best regards,
Pierre
Best regards,
Pierre
Re: Question on subroutine netcdf_get_fvar from mod_netcdf.F
Yes, this routine is inside of a module and has an interface:
F90 will pick the correct routine according the argument array or scalar A. This is fancy programming and is always in Fortran; just check the intrinsic functions.
INTERFACE netcdf_get_fvar
MODULE PROCEDURE netcdf_get_fvar_0d
MODULE PROCEDURE netcdf_get_fvar_1d
MODULE PROCEDURE netcdf_get_fvar_2d
MODULE PROCEDURE netcdf_get_fvar_3d
MODULE PROCEDURE netcdf_get_fvar_4d
END INTERFACE netcdf_get_fvar
Which field is it trying to read?
Thanks for your help!
ROMS is trying to get zeta_north(:,:) from my ocean_bry.nc file. My zeta_north(:,:) array has only one record in time, and the other dimension is space (size Lm+2). What happens then is that net_cdf_get_fvar is called over line 400 of get_ngfld:
Here Trec=1 and Iend-Istr+1=Lm+2, which correctly corresponds to the size of my zeta_north(:,:) array.
The part I find confusing is that arguments start(:) and total(:) have two elements (since zeta_north is two-dimensional), while array A(:) is one-dimensional. As Arango mentioned, that means that netcdf_get_fvar_1d is picked by Fortran, and this particular routine tries to store the two-elements array 'total(:)' into a one-element array called 'Asize(1)' around line 1960, which results in runtime error since size(total)=2 > size(Asize)=1.
Many thanks for your help,
Pierre
CALL netcdf_get_fvar (ng, mode, ncfile, Vname(1,ifield), A, ncid = ncid, start = (/1,Trec/), total = (/Iend-Istr+1,1/))
Pierre
Perhaps a minimal testcase would make things clearer:
I think it faithfully reproduces what happens. With Sun f95 I get:
I get a similar message with gfortran -fbounds-check.
Best regards,
Pierre
program testcase
implicit none
integer, parameter :: UBi = 403, LBi = -2, UBj = 1 ! Dummy values.
integer :: ng, model, ncid, Trec, Iend, Istr
character(400) :: ncfile, Vname
real, dimension((UBi-LBi+1)*UBj) :: A
! Dummy values for testcase.
ng = 1; model = 1; ncid = 0; Trec = 1; Istr = 0; Iend = 401
ncfile = 'ocean_bry.nc'; Vname = 'zeta_north'; A = 0.
! Line 400 of ROMS/Utility/get_ngfld.F (SVN rev.491M).
CALL netcdf_get_fvar_1d (ng, model, ncfile, Vname, &
A, &
ncid = ncid, &
start = (/1,Trec/), &
contains
! From module ROMS/Modules/mod_netcdf.F (SVN rev.491M)
subroutine netcdf_get_fvar_1d (ng, model, ncname, myVarName, &
A, &
ncid, &
start, &
total)
implicit none
integer, intent(in ) :: ng, model
integer, intent(in ), optional :: ncid, start(:), total(:)
character(*), intent(in ) :: ncname, myVarName
real, intent( out) :: A(:)
integer, dimension(1) :: Asize
IF (PRESENT(start).and.PRESENT(total)) THEN
Asize=total ! <= line causing runtime error.
ELSE
Asize(1)=UBOUND(A, DIM=1)
end subroutine netcdf_get_fvar_1d
end program testcase
f95 -g -C testcase.f95
./a.out
****** FORTRAN RUN-TIME SYSTEM ******
An array expression does not conform : dim 1 is 2 , not 1
Abort
Best regards,
Pierre
I suspect that the problem here is that the variable that you want to read from the NetCDF is only one-dimensional, as shown in the example above for zeta_north. This is incorrect. Any open boundary value for ROMS must be at least two-dimensional. If you check the metadata in Data/ROMS/CDL/bry_limit.cdl
You always need to have the time dimension even if it is one. Any time-dependent input NetCDF variable to ROMS needs the associated time variable and dimension. The statement in get_ngfld.F is correct. I use this logic all the time. Numerous users of ROMS use boundary files and this is the first time that this is reported. Please check your NetCDF file and let us know.
dimensions:
xi_rho = ? ; ! we need to have values for these dimensions
zeta_time = ? ;
float zeta_north(zeta_time, xi_rho) ;
zeta_north:long_name = "free-surface northern boundary condition" ;
zeta_north:units = "meter" ;
zeta_north:time = "zeta_time" ;
Thanks for this reply! Unfortunately, I checked with ncdump -h, and by opening the file in Matlab, and zeta_north correctly has two dimensions (zeta_time and xi_rho), with one record in time.
I'd be happy to test for other things if you have ideas. In the meantime, I must admit I am still puzzled about line 400 of get_ngfld.F. I mean, the testcase does generate an error, and I think the testcase is a close replicate of what happens over line 400 of get_ngfld.F. Am I missing something?
Pierre
I agree that this is strange. One reason might be that you need to check for out of bounds operation (-g -C with sun f95, or -fbounds-check with gfortran) to get the runtime error. In other words, one has to set USE_DEBUG to see something going wrong.Numerous users of ROMS use boundary files and this is the first time that this is reported.
Pierre
OK, then I need to be able to reproduce the problem. Please try other compilers to see if you get the problem. I am starting to suspect a compiler bug in gfortran. Which version of gfortran are you using?
I get the runtime error with:
gfortran (gcc version 4.3.2, from Linux Debian Lenny).
I also get the error on a different machine that uses:
f95: Sun Fortran 95 8.3 SunOS_i386 Patch 127002-04 2008/04/16
and it says
Abort
The line mentioned by the compiler is the line I highlighted in the testcase (Asize=total).
Note that I must set USE_DEBUG to "on" to get the error message.
Many thanks for this help.
Pierre
and it says
Abort
Pierre
I would be very grateful if anybody that does not encounter this issue could describe what is happening in his roms code during the reading of boundary input data such as zeta_north(:,:). It can be simply a matter of inserting a couple of write(*,*) in your code to see what roms does. Just (please) make sure that you:
- start with a fresh make clean;
- activate USE_DEBUG in roms' makefile;
- add all relevant out-of-bounds checks for your compiler in file Compilers/my_OS-my_compiler.mk under the USE_DEBUG define;
- remove all parallelization (no MPI nor OpenMP);
- make sure that your roms application really has to open a netcdf boundary file.
In my case, this is how it goes. First, ROMS/Nonlinear/get_data.F is called by roms, and it looks for the zeta boundary conditions around line 591:
So the routine ROMS/Utility/get_ngfld.F is called by roms. Then, at around line 400 of get_ngfld.F, the routine netcdf_get_fvar is requested:
In my version of roms, argument A is a one-dimensional array, which means that the call is answered by subroutine netcdf_get_fvar_1d from ROMS/Modules/mod_netcdf.F. Right at the beginning of netcdf_get_fvar_1d, I get a out-of-bound operation when it tries to execute Asize=total. This occurs because total(:) has two elements, while Asize is of size 1.
I'm particularly interested in knowing if your roms code follows the same pathway (i.e. if it calls the same routines), and what are the dimensions of the arguments in the call to these subroutines. In other words, how does your roms code avoid the out-of-bound operation that I described over this thread? I would highly appreciate if someone could help me understand this.
Many thanks,
Pierre
! Read in open boundary conditions from BOUNDARY NetCDF file.
# ifndef ANA_FSOBC
# ifdef NORTH_FSOBC
CALL get_ngfld (ng, iNLM, idZbry(inorth), ncBRYid(ng), 1, &
& BRYname(ng), update(1), &
& ILB, IUB, 1, 2, 0, Lm(ng)+1, 1, &
& BOUNDARY(ng) % zetaG_north(ILB,1))
CALL netcdf_get_fvar (ng, model, ncfile, Vname(1,ifield), &
& A, &
& ncid = ncid, &
& start = (/1,Trec/), &
& total = (/Iend-Istr+1,1/))
Many thanks,
Pierre
I finally have the time to check what you were reporting in the debugger. I tried several compilers and I was not able to reproduce the problem. However, I can see what you are talking and indeed this is a bug. It is amazing the things that modern compilers accept nowadays. Very scary... The logic here is kind of delicate because netcdf_get_fvar_1d can be used to read multi-dimensional data compacted into a 1D temporary array. This is the case when reading the open boundary data.
Many thanks for reporting this bug and your persistence with it
Please update. I think that I fixed your problem. Here is the
ticket.
I updated my code and it works great!
Thank you very much for providing this fix.
Best regards,
Pierre
Best regards,
Pierre
