netcdf-4.0.1 instatllation problems
isabelmonteiro
#1 Unread post by isabelmonteiro »
I have installed the NetCDF package apparently with no problems, after doing "make check install" I got the message: Congratulations! You have successfully installed netCDF!
But when I tried to use ncdump I get the following message:
-bash: ncdump: command not found
Can you please tell me what can be wrong ? :oops:
Re: netcdf-4.0.1 instatllation problems
I don't know about bash, but the shell I use needs a "rehash" so that it can take note of things in your path that are new since the first "hash". It builds a hash table of commands in your path to speed up finding them. Assuming of course that NetCDF got installed into a place on your path.
jacopo
#3 Unread post by jacopo »
where did you install ncdump?
If it is not in a standard path (e.g., /usr/bin/), you have to export the path netcdf-4.1/bin in your .profile
