Does FSOBC_REDUCED seem to blowup more easily
stone
#1 Unread post by stone »
I have a tide simulation with FSOBC_REDUCED since SSH_TIDE and UV_TIDE underestimate the tide amplitude.It runs smoothly when I use ssh and uv,however blowup after 12 days at the open boundary use _reduced;it grows to very negtive gradually.I check the topography is not steep with rx0<0.2 except the land is 10m deep.I tried a short time step with no help.
I have tried
fschapman + m2flather / m2reduced ,they blowup at 9hour / 12days at different open boudary.fsclamped does no help.
I have tried SPONGE,only delay the blow time one day or so.
Any suggestion please?
I use Version 333.
CPP defined:
#undef SOLVE3D
#undef SALINITY
/* Basic numerics options */
#define UV_U3HADVECTION
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#define SPLINES
#define WESTERN_WALL
#define SPONGE
#define RAMP_TIDES
#define SSH_TIDES
#define ADD_FSOBC
#define FSOBC_REDUCED
#define EAST_FSCLAMPED
#define SOUTH_FSCLAMPED
#define NORTH_FSCLAMPED
/* #define UV_TIDES
#define ADD_M2OBC */
#define EAST_M2REDUCED
#define EAST_TRADIATION
#define SOUTH_M2REDUCED
#define SOUTH_TRADIATION
#define NORTH_M2REDUCED
#define NORTH_TRADIATION
stone
Re: Does FSOBC_REDUCED seem to blowup more easily
#2 Unread post by stone »
I notice that the South Boundary is where tide propagate out,so I use the radiation BC,and it works only for 2D case;3D case(keep temp=28;salt=34) blowup(the 2nd step) at this boundary again where there is a slightly rough topography-however I used the LP_bathymetry program to smooth this,only find it seems OK
Maximum grid stiffness ratios: rx0 = 2.000000E-01 (Beckmann and Haidvogel)
rx1 = 6.530954E+00 (Haney)
It runs smoothly with non-FSOBC_REDUCED configuration,it seems that FSOBC_REDUCED is much more strick.But I really want this option.
I look through the momentum terms(where blowup happened),ubar_accel and ubar_prsgrd are ~ 1e-3 while other terms are ~ 1e-5or-6. ; And the temp/salt_adv here is also strange ~1e-3,temp/salt_rate ~ 1e-4;
u at bottom is ~7m/s and is ~1m/s at surface.
It seems the the topo still maybe the problem?
NOW I use:
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
EAST_M2REDUCED Eastern edge, 2D momentum, reduced-physics condition.
FSOBC_REDUCED Using free-surface data in reduced physics condtions
MASKING Land/Sea masking.
MIX_GEO_UV Mixing of momentum along geopotential surfaces.
NONLINEAR Nonlinear Model.
NORTH_FSCHAPMAN Northern edge, free-surface, Chapman condition.
NORTH_M2REDUCED Northern edge, 2D momentum, reduced-physics condition.
NORTH_M3RADIATION Northern edge, 3D momentum, radiation condition.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SOUTH_M2RADIATION Southern edge, 2D momentum, radiation condition.
STATIONS Writing out station data.
TS_C2VADVECTION Second-order centered vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WESTERN_WALL
Can someone help me ?
stone
#3 Unread post by stone »
1)Finally,I find out what makes it blowup(and makes me crazy) is UV_VIS2.
Without this cpp, it runs longer( at least 9 days).I can't understand why?!
2)And it blowup when I use M2reduced at Southern OB, it can run with South_M2radiation just as I mentioned.
I also wonder is it just be fine enough with Open Boundary bathymetry ratio rx0<0.2, Or I need more flat OB bathymetry? And would this affect the interior point's instability?
3)The baroclinic step also affect, I only use constant Tempreture and Salinity.
How would this affect the instability in this case.
Please forgive my ignorance, and give me some guide.
Thanks.
If your temperature and salinity are uniform, then you shouldn't be getting pressure gradient errors. Therefore, the bottom steepness should be fine.
Since you are using the U3HADVECTION, you will likely be able to get away without explicit horizontal smoothing - some small amount is built into that advection scheme.
Bathymetric steepness at the boundary: what we usually look for is to have the boundary come into the coast at right angles so that the flow isn't hitting the boundary obliquely.
I have very, very little experience with the reduced boundary conditions, so can't help you there.
