Problem with reading grid size!
leikvin
#1 Unread post by leikvin »
Dear Roms-friends,
I am a new user to ROMS, and my understanding is still limited :D .
I am now going to run a 2D-model, to get indications on the barotropic component of the ocean current in the model domain.
I want have a parallel run, with MPI. I have compiled the structure, OK.
I have Netcdf installed, but I am not sure if it is correctly done, yet.
In my PROJECT.in file, I have written the dimensions of the grid (1081*1951*1).
I try to run the model, and do get a listing right away. However, when the resolution is listed, it comes up with
0000x0000x0000
How come?
Can anybody help me, please?
Best regard
leikvin
The listing is printed below:
Process Information:
Node # 1 (pid= 31162) is active.
Node # 2 (pid= 31163) is active.
Node # 3 (pid= 31164) is active.
Node # 0 (pid= 31161) is active.
Wednesday - July 22, 2009 - 3:38:45 PM
ROMS/TOMS 3.2 - enisim_100
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : mpif90
Compiler flags : -heap-arrays -ip -O3 -xW -free
Input Script : ENI_100.in
SVN Revision : 364M
Local Root : /home/ovanov/OL/roms_3.2
Header Dir : /home/ovanov/OL/roms_3.2/mycode/EniSim_100
Header file : enisim_100.h
Analytical Dir: mycode/EniSim_100
Resolution, Grid 01: 0000x0000x000, Parallel Nodes: 4, Tiling: 002x002
720 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
60 ndtfast Number of timesteps for 2-D equations between
360 nRST Number of timesteps between the writing of data
into restart fields.
2 ninfo Number of timesteps between print of information
to standard output.
90 nHIS Number of timesteps between the writing fields
into history file.
720 ndefHIS Number of timesteps between creation of new
history files.
1.0000E-01 visc2 Horizontal, harmonic mixing coefficient (m2/s)
for turbulent energy.
0.0000E+00 rdrg Linear bottom drag coefficient (m/s).
5.0000E+00 theta_s S-coordinate surface control parameter.
6.0000E-01 theta_b S-coordinate bottom control parameter.
20.000 Tcline S-coordinate surface/bottom layer width (m) used
54191.000 dstart Time-stamp assigned to model initialization (days).
18581117.00 time_ref Reference time for units attribute (yyyymmdd.dd)
2.5000E+01 Znudg Nudging/relaxation time scale (days)
2.5000E+01 M2nudg Nudging/relaxation time scale (days)
2.5000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
2.5000E+01 obcfac Factor between passive and active
6.000 T0 Background potential temperature (C) constant.
34.800 S0 Background salinity (PSU) constant.
Prefix for History Files: ocean_his
Input Grid File: ENI_100_v3_grd.nc
Input Nonlinear Initial File: ENI_100_v3_ini.nc
Input Forcing File 01: ENI_100m_windstress_Uni.nc
Input Forcing File 02: ENI_100_tidal_frc_v3.nc
Input Climatology File: ENI_100_clm.nc
Input Boundary File: ENI_100_bry.nc
Input/Output USER File: External/MyFile.dat
Generic User Parameters:
2.5000E+01 user(01) User parameter 01.
2.5000E+01 user(02) User parameter 02.
Tile partition information for Grid 01: 0000x0000x0000 tiling: 002x002
tile Istr Iend Jstr Jend Npts
0 1 0 1 0 0
INP_PAR - domain decomposition error in input script file for grid: 1
The domain partition parameter, NtileI = 2
is incompatible with grid size, Lm = 0
because it yields too small tile, Istr = 1 Iend = 0
Decrease partition parameter: NtileI
Elapsed CPU time (seconds):
4 total processes killed (some possibly by mpirun during cleanup)
Re: Problem with reading grid size!
To run in 2D, you need to turn off SOLVE3D. For a 2D run, you need to have NDTFAST == 1. In this,
          Lm == 540           ! Number of I-direction INTERIOR RHO-points
          Mm == 768           ! Number of J-direction INTERIOR RHO-points
           N == 42            ! Number of vertical levels
it will completely ignore the N value and will not attempt to print it.
leikvin
#3 Unread post by leikvin »
Thank you for help, Kate!
Now I have done a new effort in switching off all 3D-options.
However, still I seem to not manage to read the grid size numbers from the .in file.
Why?
I still get 0000x0000x0000, even if I have numbers written in the .in-file.
Is it true that the .in-file-options are listed in the ocean.out file, before the .nc-files actually are read, or am I wrong here?
Could it be something wrong with the mpi-options, or perhaps the grid dimension? Anyway, I thought that the .in-file options would be listed first.
All other options seems to be read correctly, apart from the grid size!
Hoping for help...
Best regards
leikvin
Output from the ocean.out-file:
Node # 0 (pid= 27116) is active.
Node # 1 (pid= 27117) is active.
Node # 2 (pid= 27118) is active.
Node # 3 (pid= 27119) is active.
Thursday - August 20, 2009 - 4:29:16 PM
ROMS/TOMS 3.2 - eni_100
SVN Revision : 364M
1 ndtfast Number of timesteps for 2-D equations between
to standard output.
into history file.
history files.
Tile partition information for Grid 01: 0000x0000 tiling: 002x002
0 1 0 1 0 0
Yes, the ocean.in file is read very early in the initialization - it provides the file names to be read.
Are you sure you have lines something like these?
          Lm == 14            ! Number of I-direction INTERIOR RHO-points
          Mm == 12            ! Number of J-direction INTERIOR RHO-points
           N == 1             ! Number of vertical levels
If so, I'd break out the debugger and watch what happens in inp_par.
leikvin
#5 Unread post by leikvin »
Hi, again!
Now I have set debug to "ON" in the makefile, and I do receive an "oceanG"-file when compiling.
When trying to run the model, I still get the same output in the ocean.out-file like written above, even if the debugger has been activated (or have I missed something?). The oceanG-file seems to be somewhat bigger than the oceanM-file, so it seems to be working. I have also removed the oceanM-file, just to be sure.
I have been looking at the inp_par-file, but I am not sure exactly what to look for...
In the ocean.in-file it is, amongst others, written:
Lm == 1079 ! Number of I-direction INTERIOR RHO-points
Mm == 1949 ! Number of J-direction INTERIOR RHO-points
Nbed == 0 ! Number of sediment bed layers
NAT == 0 ! Number of active tracers
NPT == 0 ! Number of inactive passive tracers
NCS == 0 ! Number of cohesive (mud) seidment tracers
NNS == 0 ! Number of non-cohesive (sand) sediment tracers
NtileI == 2 ! I-direction partition
NtileJ == 2 ! J-direction partition
! Time-Stepping parameters.
NTIMES = 720 ! run for 12 hours total
DT == 60.0d0 ! long time step every 1 min
NDTFAST == 1 ! short time step every 1 sec
Have I forgotten something when trying to run in debugging mode?
Any tip on how to progress?
All ideas are welcome :roll:
Best regards
leikvin
#6 Unread post by kate »
Well, the point of the oceanG file is that you run it from within a debugger. The one I use is totalview, which is one of the few to work with parallel codes.
leikvin
#7 Unread post by leikvin »
Jippiii!
Finally finding the reason for not being able to read the .in-file properly.
The reason was that there was about 5 <TAB>s spread over the infile, which confused the model to not read variables properly. This was the case with the grid size!!!
I removed these <TAB>s and then I managed to progress further :D
On we go!
leikvin
