problem compilling ROMS(2)/linux-pgi(paraller)
slvester
Location: second institution of oceanography,state oceanic administration China
#1 Unread post by slvester »
Hello everyone.
I finished the make operator yesterday and got the file oceanM.But I find that there are so much confusion code in the file,is it normal?
so when I enter:
./oceanM < ROMS/External/ocean_upwelling.in
there are error:PMGR_COLLECTIVE ERROR: unitialized MPI task: Missing required environment variable: MPIRUN_RANK
so there are some relations between them?
thanks for any attantion!
Re: problem compilling ROMS(2)/linux-pgi(paraller)
#3 Unread post by arango »
It seems that you are not following the available instructions correctly :!: Use the build script instead. It is not necessary to modify the makefile. Your posts are telling me that you are not reading any of the information that it is available on WikiROMS.
slvester
#4 Unread post by slvester »
ok,thank you!
arango wrote:Your posts are telling me that you are not reading any of the information that it is available on WikiROMS.
thanks for your suggestion!I will read it more seriously
