ROMS with MATLAB..!
ROMS with MATLAB..!
I recently came to know from Mr. Arango sir that there are two versions of ROMS. First is the one which is available on the repository. And the second is the one which is developed by the French group.
Well, at the beginning i was working with the Model that was developed by the French group. I was struck up at the compilation process. Later on i tried to work with this version of model. Infact am still trying. Not getting proper hand on it.
Can anyone tell me whether this version of ROMS will work along with MATLAB?
Secondly, kindly can anyone give me any contact of the French group who developed the other version of ROMS.?
Thank You in advance.
You can reach the French group by going to their web page
(http://www.brest.ird.fr/Roms_tools) and follow the given contacts at the bottom of the entry page.
Thank you very much.. i am working with this version of roms i typed make command in the console and i got the following message
make
/bin/sh: ROMS/Bin/cpp_clean: Permission denied
makefile:230: INCLUDING FILE Compilers/make_macros.mk WHICH CONTAINS APPLICATION -DEPENDENT MAKE DEFINITIONS
/usr/bin/cpp -P -traditional -DLINUX -DX86_64 -DGFORTRAN -D'ROOT_DIR="/home/ykso ma/ROMS/trunk"' -DUPWELLING -D'HEADER="upwelling.h"' -D'ROMS_HEADER="upwelling.h "' -DNestedGrids=1 -D'ANALYTICAL_DIR="/home/yksoma/ROMS/trunk/ROMS/Functionals"' -D'SVN_REV="exported"' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Uti lity -IROMS/Drivers -IROMS/Functionals -IMaster -ICompilers -D'HEADER_DIR="./ROM S/Include"' ROMS/Nonlinear/bbl.F > Build/bbl.f90
ROMS/Bin/cpp_clean Build/bbl.f90
make: execvp: ROMS/Bin/cpp_clean: Permission denied
make: *** [Build/bbl.f90] Error 127
what may be the problem.. could u give me some suggestions..
thanks in advance
make
thanks in advance
- Location: Laboratoire d'Océanographie et du Climat - CNRS
If you are using the so callled french version (also known as AGRIF version because of its online nesting capability) you should compile the code by running jobcomp (a script that takes care of creating the makefile based on your most intimate wishes and executing it for you).
Most importantly if you are starting with this version you should follow the excellent tutorial available as part of the documentation.
ROMS and MATLAB
Many people use Matlab to create and modify the *.nc (netcdf) files that are used for grid, forcing, and output files. To do this, you need to install the mexcdf interface for Matlab. I think there are other postings on the board that explain how to do this. good luck...
Myself Mr. Rakesh Patil, working as a project assistant in National Institute of Oceanography, GOA, INDIA. I'm working on ROMS in my project which is related to coastal altimetry. I have a small doubt sir. I hope it will be cleared from you. I'm working on Linux OpenSUSE 10.3 version. I'm using ROMS with Matlab 7.4.
I'm not able to compile the model. Following are the stpes i followed.
1) I ran a matlab session in Roms_tools/Run directory
2) Then I ran start.m script. This scripts adds the various paths of toolboxes.
3) next i ran make_grid command.
4) after this i ran make_forcing
5) after make_forcing, pathfinder_sst, next make_bulk, and finally make_clim
I did the same as it was mentioned in documentation. Finally, i opened a terminal(console) and compiled the said file: jobcomp as
:> tcsh jobcomp
I got the following response:
:~/Roms_tools/Run> tcsh jobcomp
OPERATING SYSTEM IS: Linux
PROCESSOR IS: x86_64
SIXTYFOUR
cp: No match.
fpp: Command not found.
/bin/rm -rf core *.o AGRIFZOOM/AGRIF_YOURFILES/*.o *.i *.s *.f *.trace *.mod
/bin/rm -rf roms mpc cross_matrix cppcheck srcscheck checkkwds partit ncjoin ncrename ./rii_files
fpp -free -P -I../netcdf_x86_64 mpc.F > mpc.f
/bin/sh: fpp: command not found
gmake: *** [mpc] Error 127
fpp -free -P -I../netcdf_x86_64 main.F | ./mpc > main.f
/bin/sh: ./mpc: No such file or directory
gmake: *** [main.o] Error 127
i'm not able to go forward as i'm confused with what is the error and how to rectify the error. It will be very grateful of you if you give me proper guidance. Waiting for your earliest reply.
Thank You
:> tcsh jobcomp
SIXTYFOUR
cp: No match.
Thank You
Hi Rakesh,
You have to modify jobcomp to point where is in your system the fortran pre processor, fpp. What fortran processor do you have in your system? Have you installed the Intel fortran compiler? What do you get if you type
locate fpp
at the shell?
Regards,
Andres
locate fpp
at the shell?
Regards,
Andres
rakeshthp wrote: :> tcsh jobcomp
SIXTYFOUR
cp: No match.
Thank You
locate fpp
Hi.. I got this message..
> locate fpp
/usr/bin/diffpp
/usr/bin/dprofpp
/usr/share/man/man1/diffpp.1.gz
/usr/share/man/man1/dprofpp.1.gz
/windows/C/Perl/html/bin/dprofpp.html
which part of jobcomp file do i need to change..???
> locate fpp
/usr/bin/diffpp
/usr/bin/dprofpp
Re: locate fpp
Hi
[andres@localhost daily_run]$ which fpp
/usr/local/bin/fpp
but as you can see
[andres@localhost daily_run]$ ls -l /usr/local/bin/fpp
lrwxrwxrwx 1 root root 25 May 23 2006 /usr/local/bin/fpp -> /opt/intel/fc/9.0/bin/fpp
fpp comes as part of the Intel Fortran Compiler that I have installed. Which Fortran compiler do you use? Intel, PG, gfortran?
Andres
The problem now is not a modification of the jobcomp file. Seems you dont have the fpp program that is needed, which is called by jobcomp. Here is what I have in my system:rakeshthp wrote:Hi.. I got this message..
> locate fpp
/usr/bin/diffpp
/usr/bin/dprofpp
/usr/local/bin/fpp
but as you can see
Andres
Re: hi..
Hi.rakeshthp wrote:my system is having gfortran compiler.. i tried all 4 combinations that is given in jobcomp.. i.e. ifort, f99 or something...
you need to modify a line at the top of the jobcomp (near line 25) declaring which fortran compiler do you use. Seems jobcomp does not include yet gfortran as an option so you should install another compliler such as g95, g77 or ifort. Can you add these compilers to your system?
Do you have the cpp installed? (Type which cpp at the command prompt)
Andres
Hi there...
cpp is installed by default on my system. I'm using Open SUSE 10.3.. i typed which cpp at command prompt. I got the following output:
/usr/bin/cpp
i think it can be compiled using cpp also na..?? i had set LINUX_FC=g77 n compiled it.. i got the following message..
gourish@spk:/home/roms/Roms_tools/Run> tcsh jobcomp
PROCESSOR IS: i686
Please provide a netcdf library
cp: No match.
cpp -traditional -DLinux -P XXX mpc.F > mpc.f
cpp: XXX: No such file or directory
cpp: warning: '-x c' after last input file has no effect
cpp: no input files
/home/roms/Roms_tools/Compile
cpp -traditional -DLinux -P XXX main.F | ./mpc > main.f
cpp: no input files
mv: cannot stat `roms': No such file or directory
whats the next step..?? should i install other fortran compiler..??
/usr/bin/cpp
PROCESSOR IS: i686
cp: No match.
cpp: no input files
cpp: no input files
It would be easier for me to help you if you install the Intel Fotran Compiler (is the one I use)...
Andres
Andres
rakeshthp wrote:Hi there...
/usr/bin/cpp
PROCESSOR IS: i686
cp: No match.
cpp: no input files
cpp: no input files
Re: ROMS with MATLAB..!
hi rakeshthp
i am very newer of roms and i use ifort too. Can you tell which part of jobcomp I should modify to go through this problem?
Can you send the screen output?
size wrote:hi rakeshthp
Andres Sepulveda
Geophysics Department
University of Concepcion
Re: HIIII
Hello,rakeshthp wrote:Thanks a lot... i installed intel fortran compiler and did some changes in jobcomp file.. and its working properly...... Thanks for all for ur kind cooperation...HAPPY NEW YEAR...
My ROMS_AGRIF can work in parallel when I defines "OPENMP". But it can not be compiled successfully when I defines "MPI".
Can you tell which part of jobcomp I should modify to go through this problem? Thank you!
set SOURCE=../Roms_Agrif
set SCRDIR=../Compile
set RUNDIR=`pwd`
# Linux compiler options (only relevant to Linux OS)
set LINUX_FC=ifort
#set LINUX_FC=ifc
#set LINUX_FC=g95
#set LINUX_FC=g77
# set 32 or 64 Bits executable
#set BITS=THIRTYTWO
set BITS=SIXTYFOUR
# set NETCDF directories
if ($BITS == THIRTYTWO) then
# set NETCDFLIB=-L$HOME/lib32
# set NETCDFINC=-I$HOME/lib32
if ($LINUX_FC == g77) then
set NETCDFLIB=-L../netcdf_g77/
set NETCDFINC=-I../netcdf_g77/
else
set NETCDFLIB=-L/public/soft/netcdf362-intel101/lib/
set NETCDFINC=-I/public/soft/netcdf362-intel101/include/
endif
else
endif
# set MPI directories if needed
set MPILIB=-L/public/soft/ompi133-intel101/lib/
set MPIINC=-I/public/soft/ompi133-intel101/include/
# END OF USER'S MODIFICATIONS
main.o: In function `MAIN__':
main.f:(.text+0x37): undefined reference to `mpi_init_'
main.f:(.text+0x3e): undefined reference to `pmpi_wtime_'
main.f:(.text+0x93): undefined reference to `mpi_barrier_'
main.f:(.text+0x9a): undefined reference to `pmpi_wtime_'
main.f:(.text+0x141): undefined reference to `mpi_finalize_'
read_inp.o: In function `read_inp_':
read_inp.f:(.text+0x85): undefined reference to `mpi_bcast_'
setup_grid2.o: In function `setup_grid2_tile_':
setup_grid2.f:(.text+0xad5): undefined reference to `mpi_send_'
setup_grid2.f:(.text+0xb27): undefined reference to `mpi_recv_'
setup_grid2.f:(.text+0xd40): undefined reference to `mpi_bcast_'
setup_grid2.o: In function `setup_grid2_':
setup_grid2.f:(.text+0x1be7): undefined reference to `mpi_send_'
setup_grid2.f:(.text+0x1c3c): undefined reference to `mpi_recv_'
setup_grid2.f:(.text+0x1e53): undefined reference to `mpi_bcast_'
set_nudgcof.o: In function `set_nudgcof_tile_':
set_nudgcof.f:(.text+0xf5): undefined reference to `mpi_bcast_'
set_nudgcof.o: In function `set_nudgcof_':
set_nudgcof.f:(.text+0xfe6): undefined reference to `mpi_bcast_'
diag.o: In function `diag_tile_':
diag.f:(.text+0x1215): undefined reference to `mpi_send_'
diag.f:(.text+0x126b): undefined reference to `mpi_recv_'
diag.o: In function `diag_':
diag.f:(.text+0x288a): undefined reference to `mpi_send_'
diag.f:(.text+0x28e0): undefined reference to `mpi_recv_'
grid_stiffness.o: In function `grid_stiffness_tile_':
grid_stiffness.f:(.text+0x6da): undefined reference to `mpi_send_'
grid_stiffness.f:(.text+0x71d): undefined reference to `mpi_recv_'
grid_stiffness.f:(.text+0x79e): undefined reference to `mpi_bcast_'
grid_stiffness.o: In function `grid_stiffness_':
grid_stiffness.f:(.text+0xfa2): undefined reference to `mpi_send_'
grid_stiffness.f:(.text+0xfe6): undefined reference to `mpi_recv_'
grid_stiffness.f:(.text+0x1067): undefined reference to `mpi_bcast_'
wrt_his.o: In function `wrt_his_':
wrt_his.f:(.text+0x55): undefined reference to `mpi_recv_'
wrt_his.f:(.text+0x1047): undefined reference to `mpi_send_'
wrt_rst.o: In function `wrt_rst_':
wrt_rst.f:(.text+0x55): undefined reference to `mpi_recv_'
wrt_rst.f:(.text+0xcc0): undefined reference to `mpi_send_'
wrt_avg.o: In function `wrt_avg_':
wrt_avg.f:(.text+0x55): undefined reference to `mpi_recv_'
wrt_avg.f:(.text+0x75f): undefined reference to `mpi_send_'
MPI_Setup.o: In function `mpi_setup_':
MPI_Setup.f:(.text+0x1c): undefined reference to `mpi_comm_size_'
MPI_Setup.f:(.text+0x30): undefined reference to `mpi_comm_rank_'
MessPass2D.o: In function `messpass2d_tile_':
MessPass2D.f:(.text+0x7d6): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0x80d): undefined reference to `mpi_send_'
MessPass2D.f:(.text+0xeef): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0xf26): undefined reference to `mpi_send_'
MessPass2D.f:(.text+0x14f2): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0x1526): undefined reference to `mpi_send_'
MessPass2D.f:(.text+0x1ac3): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0x1af7): undefined reference to `mpi_send_'
MessPass2D.f:(.text+0x1b8d): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0x1bc1): undefined reference to `mpi_send_'
MessPass2D.f:(.text+0x1c6a): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0x1c9e): undefined reference to `mpi_send_'
MessPass2D.f:(.text+0x1d41): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0x1d75): undefined reference to `mpi_send_'
MessPass2D.f:(.text+0x1f11): undefined reference to `mpi_wait_'
MessPass2D.f:(.text+0x1f5e): undefined reference to `mpi_wait_'
MessPass2D.f:(.text+0x1fcf): undefined reference to `mpi_wait_'
MessPass2D.f:(.text+0x2027): undefined reference to `mpi_wait_'
MessPass2D.f:(.text+0x2099): undefined reference to `mpi_wait_'
MessPass2D.o:MessPass2D.f:(.text+0x241f): more undefined references to `mpi_wait_' follow
MessPass2D.f:(.text+0x3012): undefined reference to `mpi_irecv_'
MessPass2D.f:(.text+0x3046): undefined reference to `mpi_send_'
MessPass3D.o: In function `messpass3d_tile_':
MessPass3D.f:(.text+0xc02): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0xc36): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0xd23): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0xd57): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0xe28): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0xe5c): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0xf33): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0xf67): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0x1073): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0x10a7): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0x1104): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0x1138): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0x1195): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0x11c9): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0x1226): undefined reference to `mpi_irecv_'
MessPass3D.f:(.text+0x125a): undefined reference to `mpi_send_'
MessPass3D.f:(.text+0x1288): undefined reference to `mpi_wait_'
MessPass3D.f:(.text+0x1661): undefined reference to `mpi_wait_'
MessPass3D.f:(.text+0x1adc): undefined reference to `mpi_wait_'
MessPass3D.f:(.text+0x1f19): undefined reference to `mpi_wait_'
MessPass3D.f:(.text+0x2374): undefined reference to `mpi_wait_'
MessPass3D.o:MessPass3D.f:(.text+0x2623): more undefined references to `mpi_wait_' follow
make: *** [roms] Error 1
Hi, improvechen
Seems you have a confusion between OPENMP and MPI
To use mpi you have to compile the mpich2 code indicating that you will use the intel fortran compiler.
This will generate the mpif90 executable that you have to use in the jobcomp file to compile the ROMS_AGRIF code,
set LINUX_FC=mpif90
pointing to the correct lib and include directories
set MPILIB=-L/usr/local/lib/
set MPIINC=-I/usr/local/include/
then you have to run the daemon mpd
/usr/local/bin/mpd &
and then use mpiexec in the run_roms.csh file to actually run the code
/usr/local/bin/mpiexec -n $MYCORES ./$CODFILE ${MODEL}_hindcast.in > ${MODEL}_hindcast_`date -Idate`.out
set LINUX_FC=mpif90
Andres Sepulveda
Thanks for your help.Now it works.
andres wrote:Hi, improvechen
To use ...
Hi people,
I'm a little confused, so Anybody can help me with this issue?
I'm running for inter annual analysis (with ./roms roms_inter.in), and I get the following:
]$ ./roms roms_inter.in
ERROR in MPI_Setup: number of MPI-nodes should be 8 instead of 1.
exe_time = 0.000000000000000E+000
But, I've defined MPI in cppdesf.and edited param.h:
#ifdef MPI
integer NP_XI, NP_ETA, NNODES
parameter (NP_XI=2, NP_ETA=4, NNODES=8)
parameter (NSUB_X=1, NSUB_E=1, NPP=1)
So, Anybody does know what It is my mistake?
Thanks, for advances,
#ifdef MPI
when you run with MPI, you need to send the job through mpirun:
mpirun -np n ./roms roms.in
where n=number of total processors used = 8 in your case.
See page 29 of the latest documentation file.
best,
Milena
best,
Milena
Thanks, Milena for your quickly answer.
You're right with MPI.![Smile :)](./images/smilies/icon_smile.gif)
Best,
Best,
