Perfect restart problem
mathieu
#1 Unread post by mathieu »
I understand that in order to have perfect restart we should select PERFECT_RESTART in the cppdefs.h file.
I do obtain the restart file with the additional variables rzeta, AKt, AKs and others.
But how can we read those variables? The crux of the matter appears to be in the get_state subroutine. The following code section
      Perfect2D=.FALSE.
      Perfect3D=.FALSE.
#ifdef PERFECT_RESTART
      IF ((model.eq.0).and.(nrrec(ng).ne.0)) THEN
        Perfect2D=.TRUE.
        Perfect3D=.TRUE.
      PerfectRST(ng)=Perfect2d.or.Perfect3d
shows the problem. In order to read the additional variables, we need to have the variable model equal to 0 but get_state is called with model=iNLM that is 1 from the initial subroutine.
mathieu
Re: Perfect restart problem
#2 Unread post by mathieu »
I got it. In order to read the perfect restart file, it is necessary to use the option ANA_INITIAL.
Maybe this should be said in the cppddefs.h, i.e. replace
** ANA_INITIAL         use if analytical initial conditions                  **
by
** ANA_INITIAL         use if analytical initial conditions or from perfect restart file   **
