When ana_sediment is defined & there is an initial nc file..
LauraB
#1 Unread post by LauraB »
Hi ROMS community,
I wanted to add sediments to my model. My initial conditions for physics and biology were given in a netcdf file, while I wanted analytical conditions for the sediments. As far as I understand, whenever ana_* is defined, analytical initial fields are used (even if there is an initial netcdf file). However, I got the following error:
NLM: CHECKVARS - unable to find model variable: grain_diameter
in file: /home/ROMS_LB/Bioupw21/initial_21a2.nc
Analytical header files used:
/home/ROMS_LB/User/Functionals/ana_grid.h
/home/ROMS_LB/User/Functionals/ana_hmixcoef.h
/home/ROMS_LB/User/Functionals/ana_sediment.h
I think the problem was in checkvars.F, where get_var didn't check for bottom variables (idBott) inside the "# ifdef ANA_SEDIMENT" loop. Below I copy the piece of code with my modifications. I look forward to hearing your opinions about this fix!
Best,
Laura
Utility/checkvars.F:
# ifdef SEDIMENT
        IF (nrrec(ng).ne.0) THEN
          DO itrc=1,NST
            get_var(idTvar(idsed(itrc)))=.TRUE.
            get_var(idfrac(itrc))=.TRUE.
            get_var(idBmas(itrc))=.TRUE.
          DO itrc=1,MBEDP
            get_var(idSbed(itrc))=.TRUE.
!---by LB: need to look for Bott initial conds at ana_sed
          DO itrc=1,MBOTP
            get_var(idBott(itrc))=.TRUE.
#  else
        DO itrc=1,NST
        DO itrc=1,MBEDP
#  endif
#  ifdef BEDLOAD
          DO itrc=1,NST
            get_var(idUbld(itrc))=.TRUE.
            get_var(idVbld(itrc))=.TRUE.
#  endif
#  ifdef SED_MORPH
          get_var(idbath)=.TRUE.
#  endif
# if defined SEDIMENT || defined BBL_MODEL
!---by LB: need to skip this step if ana_sed was defined...
#   ifndef ANA_SEDIMENT
        DO itrc=1,MBOTP
#  endif
Re: When ana_sediment is defined & there is an initial nc file..
Was this a restart (nrrec.ne.0)?
Did your fix work?
LauraB
#3 Unread post by LauraB »
Thanks for the reply! This wasn't a restart run (nrrec=0), so I realize now -after your comment- that the DO loop I added is not being used at all! (and probably should be removed)
However, the fix worked and the run is still going on. So it looks like the extra "# ifndef ANA_SEDIMENT" is doing the trick... Yesterday I checked the first few data saved in the history file, and it is reading correctly the initial conditions for sediments (including grain_diameter, which was the one that triggered the error before).
Regards,
Laura
#4 Unread post by arango »
I finally have time to look at this issue. Yes, thank you. There is a missing logic here when the bottom properties are specified with analytical expressions (ANA_SEDIMENT) in sediment of BBL applications. There is not need for the logic that you added inside of the #ifdef SEDIMENT. This logic is taken care for both SEDIMENT and BBL_MODEL below the above logic.
See the following trac :arrow: ticket for more details. Please update :wink:
