Sediment for beginner))
fancer
Location: NNSTU, The Nizhniy Novgorod State Technical University named after R.E.Alekseev, Russia
#1 Unread post by fancer »
Hello, I attend sediment transport to a problem. I have already learnt to collect ROMS for the necessary problem, whether it be sediment transport or not, and to start processing. You could not help?
1) how to set a step on time and time?
2) what should be source files and that each of them means.
3) where I can find detailed description shoreface for ROMS?
Many thanks for the help!))))
PS Probably, it not the last my questions))))
Re: Sediment for beginner))
A lot of information you seek is on the wiki site:
https://www.myroms.org/wiki/index.php/D ... ion_Portal
fancer
#3 Unread post by fancer »
I'm so sorry for my english)))) I still study)))
I have read all in wiki-site, but I have not found something concrete about NetCDF input files and what should be in this files. For example, in ROMS/External/ocean_sed_test1.in:
GRDNAME == ocean_grd.nc
ININAME == ocean_ini.nc
ITLNAME == ocean_itl.nc
IRPNAME == ocean_irp.nc
IADNAME == ocean_iad.nc
CLMNAME == ocean_clm.nc
BRYNAME == ocean_bry.nc
FWDNAME == ocean_fwd.nc
ADSNAME == ocean_ads.nc
But how ROMS calculate without this files?((( What ROMS use as defaults files instead files in this list?
And how I can assign bathymetry?
ps A step on time assign in ROMS/External/ocean_sed_test1.in)))
#4 Unread post by jcwarner »
well, roms does not need all these files for all applications. It depends on what you are doing. So it typically will need an grid file (GRDNAME) and an init file (ININAME).
Grid files can be difficult to create, but there is info on the wiki to make these.
fancer
#5 Unread post by fancer »
Thank You very much for help)))
I run SHOREFACE application, but it crash with segmentation fault error. Step by step:
1) in makefie:
ROMS_APPLICATION ?= SHOREFACE
2) in cppdefs.h no one word about SHOREFACE (((
3) and use ROMS/External/ocean_shoreface.in:
oceanS < ROMS/External/ocean_shoreface.in >& ocean_shoreface.log &
Here log-file (Where is "attach file"-button??):
Process Information:
Thread # 0 (pid= 31509) is active.
Model Input Parameters: ROMS/TOMS version 3.2
Monday - March 30, 2009 - 4:01:16 PM
Shore Face Planar Beach Test Case
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/bin/gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none
SVN Revision : 333M
Local Root : /home/fancer/ROMS/build/roms
Header Dir : /home/fancer/ROMS/build/roms/ROMS/Include
Header file : shoreface.h
Analytical Dir: /home/fancer/ROMS/build/roms/ROMS/Functionals
Resolution, Grid 01: 0059x0007x020, Parallel Threads: 1, Tiling: 001x001
4320 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
360 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
720 nAVG Number of timesteps between the writing of
1 ntsDIA Starting timestep for the accumulation of output
720 nDIA Number of timesteps between the writing of
0.0000E+00 visc2 Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
1.5000E-03 rdrg2 Quadratic bottom drag coefficient.
1.5000E-02 Zob Bottom roughness (m).
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
0.0000E+00 theta_s S-coordinate surface control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idU2rs) Write out total 2D u-radiation stress.
T Hout(idV2rs) Write out total 2D v-radiation stress.
T Hout(idU2Sd) Write out 2D u-momentum stokes velocity.
T Hout(idV2Sd) Write out 2D v-momentum stokes velocity.
T Hout(idW3xx) Write out 3D horizonrtal radiation stress, Sxx.
T Hout(idW3xy) Write out 3D horizonrtal radiation stress, Sxy.
T Hout(idW3yy) Write out 3D horizonrtal radiation stress, Syy.
T Hout(idW3zx) Write out 3D vertical radiation stress, Szx.
T Hout(idW3zy) Write out 3D vertical radiation stress, Szy.
T Hout(idU3rs) Write out total 3D u-radiation stress.
T Hout(idV3rs) Write out total 3D v-radiation stress.
T Hout(idU3Sd) Write out 3D u-momentum stokes velocity.
T Hout(idV3Sd) Write out 3D v-momentum stokes velocity.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wave length.
T Hout(idWdir) Write out wave direction.
T Hout(idBott) Write out bottom property 15: active_layer_thickness
T Hout(idVvis) Write out vertical viscosity coefficient.
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Output Diagnostics File: ocean_dia.nc
Input Forcing File 01: Data/ROMS/Forcing/swan_shoreface_angle_forc.nc
Tile partition information for Grid 01: 0059x0007x0020 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 59 1 7 8260
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -0.50 60.50 -3.50 10.50 RHO-points
0 -0.50 60.50 -3.50 10.50 U-points
0 -0.50 60.50 -3.50 10.50 V-points
Sediment Parameters, Grid: 01
1 1.0000E+00 0.0000E+00 2.6500E+03 1.0000E+00 1.0000E-05 5.0000E-01
tau_ce tau_cd tnu2 tnu4 Akt_bak Tnudg
1 7.0000E-02 2.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+00
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.50000E-01
T Hout(idTvar) Write out sediment01: sand_01
T Hout(idfrac) Write out bed fraction, sediment 01: sandfrac_01
T Hout(idfrac) Write out mass, sediment 01: sandmass_01
T Hout(idUbld) Write out bed load at U-points, sediment 01: bedload_Usand_01
T Hout(idVbld) Write out bed load at V-points, sediment 01: bedload_Vsand_01
T Hout(idSbed) Write out BED property 03: bed_porosity
SHOREFACE Shore Face Planar Beach Test Case
ANA_GRID Analytical grid set-up.
ANA_MASK Analytical Land/Sea Masking.
ANA_SEDIMENT Analytical sediment initial conditions.
AVERAGES_BELOAD Writing out time-averaged bed load.
AVERAGES_NEARSHORE Writing out time-averaged nearshore radiation fields.
BEDLOAD_MPM Activate bed load sediment transport Meyer-Peter-Mueller.
EASTERN_WALL Wall boundary at Eastern edge.
MASKING Land/Sea masking.
NEARSHORE_MELLOR Nearshore RAdiation Stress Terms.
NONLINEAR Nonlinear Model.
NS_PERIODIC North-South periodic boundaries.
OUT_DOUBLE Double precision output fields in NetCDF files.
THREE_GHOST Using three Ghost Points in halo regions.
UV_ADV Advection of momentum.
WEST_FSCHAPMAN Western edge, free-surface, Chapman condition.
WEST_M2FLATHER Western edge, 2D momentum, Flather condition.
WEST_M3GRADIENT Western edge, 3D momentum, gradient condition.
WET_DRY Wetting and drying activated.
Vertical S-coordinate System:
20 0.0000000 0.0000000 0.000 0.000 0.000
19 -0.0500000 -0.0500000 0.150 -0.219 -0.588
18 -0.1000000 -0.1000000 0.300 -0.438 -1.175
17 -0.1500000 -0.1500000 0.450 -0.656 -1.763
16 -0.2000000 -0.2000000 0.600 -0.875 -2.350
15 -0.2500000 -0.2500000 0.750 -1.094 -2.938
14 -0.3000000 -0.3000000 0.900 -1.313 -3.525
13 -0.3500000 -0.3500000 1.050 -1.531 -4.113
12 -0.4000000 -0.4000000 1.200 -1.750 -4.700
11 -0.4500000 -0.4500000 1.350 -1.969 -5.288
10 -0.5000000 -0.5000000 1.500 -2.188 -5.875
9 -0.5500000 -0.5500000 1.650 -2.406 -6.463
8 -0.6000000 -0.6000000 1.800 -2.625 -7.050
7 -0.6500000 -0.6500000 1.950 -2.844 -7.638
6 -0.7000000 -0.7000000 2.100 -3.063 -8.225
5 -0.7500000 -0.7500000 2.250 -3.281 -8.813
4 -0.8000000 -0.8000000 2.400 -3.500 -9.400
3 -0.8500000 -0.8500000 2.550 -3.719 -9.988
2 -0.9000000 -0.9000000 2.700 -3.938 -10.575
1 -0.9500000 -0.9500000 2.850 -4.156 -11.163
0 -1.0000000 -1.0000000 3.000 -4.375 -11.750
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136461 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792859
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876602
10 0.0161716623600090 0.0486998273761630 0.0421751148367487 0.4983983377638232
11 0.0207585511322367 0.0478912442581626 0.0629336659689854 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430844 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924698 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366960 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873357 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240973 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194840 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038024 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834594 0.9445203630883545
23 0.0746596950216180 0.0177785909158270 0.7190878767050775 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669234 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836260 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321980 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218105 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740009 0.9996892670186999
29 0.0062146596259991 0.0003107329813000 1.0000000000000000 0.9999999999999998
ndtfast, nfast = 20 29 nfast/ndtfast = 1.45000
Minimum X-grid spacing, DXmin = 2.00000000E-02 km
Maximum X-grid spacing, DXmax = 2.00000000E-02 km
Minimum Y-grid spacing, DYmin = 2.00000000E-02 km
Maximum Y-grid spacing, DYmax = 2.00000000E-02 km
Minimum Z-grid spacing, DZmin = -1.50000000E-01 m
Maximum Z-grid spacing, DZmax = 5.87500000E-01 m
Minimum barotropic Courant Number = 1.23806805E-02
Maximum barotropic Courant Number = 1.89792238E-01
Maximum Coriolis Courant Number = 0.00000000E+00
GET_2DFLD - wind-induced wave direction, t = 0 00:00:00
(Rec=0001, Index=1, File: swan_shoreface_angle_forc.nc)
(Tmin= 0.0000 Tmax= 0.0000)
(Min = 3.14159265E+00 Max = 4.73490388E+00)
GET_2DFLD - wind-induced significant wave height, t = 0 00:00:00
(Min = 0.00000000E+00 Max = 2.20400000E+00)
GET_2DFLD - wind-induced mean wavelength, t = 0 00:00:00
(Min = 1.00000000E+01 Max = 7.05299988E+01)
Maximum grid stiffness ratios: rx0 = 1.685714E+00 (Beckmann and Haidvogel)
rx1 = 6.574286E+01 (Haney)
Initial basin volumes: TotVolume = 7.22750000000000E+05 m3
MinVolume = -5.50833333333334E+01 m3
MaxVolume = 2.30083333333334E+02 m3
Max/Min = -4.17700453857791E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00004320)
0 0 00:00:00 0.000000E+00 3.856303E+01 3.856303E+01 7.732200E+05
#6 Unread post by jcwarner »
why did it crash?? you say it crashes with seg fault error, but i do not see that error in the log file.
fancer
#7 Unread post by fancer »
After last line:
In terminal next message:
segmentation fault
ps I can give more info, if it necessary))
#8 Unread post by jcwarner »
i do not use gfortran. may be try to compile with debug on, run it, and see if that gives more information.
fancer
#9 Unread post by fancer »
I do not know why, but on other computer (at home) all work))) without seg fault)))
Can You answer me, please?
1) How ROMS calculate without grid, frc and others file or give me link with answer?
2) What mean variables rho and psi? This is density and flow function (current function) accordingly?
#10 Unread post by jcwarner »
1) ROMS can not calculate without grid. That is required.
So you must be doing something different.
I strongly suggest that you look more carefully at info on the wiki. Perhpas at first, you should try to just run the upwelling case (the default case) and make sure that works for you.
Then move on to try anohter example.
2) the variable 'rho' is density perturbation.
the variable 'psi' is most likely the length scale term of the GLS turbulence closure. Did you define GLS_MIXING?
#11 Unread post by kate »
Psi is a horizontal streamfunction from a previous generation of the model. It is located at the corners of the grid boxes while rho is located at the centers of grid boxes.
fancer
#12 Unread post by fancer »
2 jcwarner:
1) Thanks You, I more careful look the wiki page and see many interesting:))))
2) I already started sed_test1 and shoreface and upwelling case too and all work correctly))
2 kate:
Thanks You for your help)))
Question for all:
Where more easy generating grid-, force-, initial-files (in Linux) for beginner?)))
fancer
#13 Unread post by fancer »
Hello all developers)))
I've any questions about SHOREFACE example:
1) I don't understand about wave direction as a whole. How explain what a wave come to beach with 270 degrees? I know what coordinates illustrate like this:
|0
270 | 90
|180
Or not? And why 180 degrees on a beach? And angle with what objects this degrees illustrate?
2) How can I see or what dimension illustrate changes bathymetry with time? May be some dimension h(x,y,t)???
Thanks a lot for all answers)))
ps I'm sorry for my english)))
#14 Unread post by jcwarner »
SWAN is a full 3D model.We typically use SET NAUTICAL so that wave and winds are the directions that they are coming from. So a wave direction of 270 would mean waves are coming from the west.
IF you activate
#define SED_MORPH
then a variable 'bath(t,z,y,x)' can be available in the history files. You need to set:
Hout(idBath) == T ! time-dependent bathymetry
in the ocean*.in file.
fancer
#15 Unread post by fancer »
Thanks a lot. You very helped)))
