NetCDF compilation problems on Pentium III - Red Hat Linux
Frequently Asked Questions about ROMS usage
Moderators: arango, kate, robertson
prosperi
#1 Unread post by prosperi »
Hi All,
I am trying to make a local installation of ROMS on my computer (Pentium III, O.S = Red Hat 7.2 (Enigma)). I have some problems...
Actually, I started trying to create a grid NetCDF by using the coast and grid packages. I have a problem creating the NetCDF library. I followed the instructions in the UNIDATA INSTALL.html pages. Everything seems to go well until I lunch the "make" command giving:
make[1]: Entering directory `/usr/local/netcdf-3.5.0/src'
Making `all' in directory /usr/local/netcdf-3.5.0/src/libsrc
make[2]: Entering directory `/usr/local/netcdf-3.5.0/src/libsrc'
cc -c -O -I.  -DNDEBUG attr.c
In file included from /usr/include/errno.h:36,
                 from netcdf.h:39,
                 from nc.h:16,
                 from attr.c:8:
/usr/include/bits/errno.h:25:26: linux/errno.h: No such file or directory
make[2]: *** [attr.o] Error 1
make[2]: Leaving directory `/usr/local/netcdf-3.5.0/src/libsrc'
make[1]: *** [subdir_target] Error 1
make[1]: Leaving directory `/usr/local/netcdf-3.5.0/src'
make: *** [libsrc/all] Error 2
So I cannot compile ROMS program because the NetCDF library hasn't been built.
Anyway, also with xpots and xcoast seems that there are some problems:
The Makefile.gcc assumes that my X files are under /usr/local/X11R6, actually they are in /usr/X11R6, so I created a simbolic link before to lunch the "make depend" and "make" command..the result is the same..
Concerning xpots, an interface is created, but is impossible "move" the switches..
Does cpp need to any option to compile correctly the .h files?
Thank you, Davide
#2 Unread post by arango »
There are better packages for creating and editing the grid NetCDF file for ROMS. These packages use Matlab and the MEXCDF interface. There are very easy to use and have a lot new capabilities. Get the SeaGrid package. See:
http://woodshole.er.usgs.gov/staffpages ... agrid.html
CPP does not required any special flags. The new ROMS (version 2.0 uses few include files since everything is handling with F90 modules.
Perhaps, you can find help on the NetCDF web site for your problem compiling the library. Seems to me that there are some problems in your configuration file.
Good luck, H
arango@imcs.rutgers.edu
m.hadfield
You might have better luck with one of the netCDF RPMs at
http://www.rpmfind.net/linux/rpm2html/s ... ery=netcdf
Mark Hadfield
NIWA
