faulty ocean_time in diagnostics file
moritz
#1 Unread post by moritz »
I noticed that the time record (ocean_time) in the output diagnostics files is incorrect when
#undef DIAGNOSTICS_TS
and
# define DIAGNOSTICS_BIO
In the case where the diagnostics file has several output time slices, all elements of ocean_time are identical (and equal to the time of the first output slice) and in units of days.
I undefined DIAGNOSTICS_TS to save disk space and because I am fiddling with the biological model only. When DIAGNOSTICS_TS is defined the output is as expected.
Best, Moritz
Re: faulty ocean_time in diagnostics file
#2 Unread post by arango »
Yes, the problem here is that main3d was not calling set_diags. Please update your code. Thank you for reporting this problem.
