High output amplitutes in tidal simulation
dhson
#1 Unread post by dhson »
Using ROMS-3.1 for tidal simulation in South China Sea, the output tidal amplitudes in all stations seemed to much higher than expected (says, ~ 4-5m compared to ~1.5-2m).
The following CPPs were used:
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#define MIX_S_TS
#undef TS_MPDATA
#undef UV_PSOURCE
#undef TS_PSOURCE
#define SPLINES
#define STATIONS
#define FLOATS
#undef EASTERN_WALL
#undef WESTERN_WALL
#undef SOUTHERN_WALL
#undef NORTHERN_WALL
#undef SPONGE
#define RADIATION_2D
#define RAMP_TIDES
#define SSH_TIDES
# define ADD_FSOBC
# define EAST_FSCHAPMAN
# define NORTH_FSCHAPMAN
# define WEST_FSCHAPMAN
# define SOUTH_FSCHAPMAN
#define UV_TIDES
# define ADD_M2OBC
# define EAST_M2FLATHER
# define NORTH_M2FLATHER
# define WEST_M2FLATHER
# define SOUTH_M2FLATHER
#define EAST_M3RADIATION
#define EAST_TRADIATION
#define EAST_TNUDGING
#define NORTH_M3RADIATION
#define NORTH_TRADIATION
#define NORTH_TNUDGING
#define WEST_M3RADIATION
#define WEST_TRADIATION
#define WEST_TNUDGING
#define SOUTH_M3RADIATION
#define SOUTH_TRADIATION
#define SOUTH_TNUDGING
#ifdef SOLVE3D
# define GLS_MIXING
# ifdef GLS_MIXING
# if defined SEDIMENT || defined SG_BBL || defined MB_BBL || defined SSW_BBL
# define ANA_SEDIMENT
# define ANA_BSFLUX
# define ANA_SSFLUX
# define ANA_BTFLUX
# undef ANA_STFLUX
# undef ANA_BPFLUX
# undef ANA_SPFLUX
# undef ANA_SRFLUX
# define DIURNAL_SRFLUX
#define QCORRECTION
#define SOLAR_SOURCE
Although the tidal forcings reproduced by Roms_tools through TPXO7 were reasonable (I've checked) the output screen showed quite high input values of tidal elevation amplitude and maximum tidal current as:
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 2.38071599E+06)
(Min = 7.32374201E-05 Max = 2.11612036E+01)
(Min = 1.27267371E-05 Max = 6.28318530E+00)
(Min = 1.76610601E-06 Max = 6.28318321E+00)
(Min = 5.46455752E-06 Max = 6.28318301E+00)
(Min = 9.11001471E-07 Max = 2.96800211E+01)
(Min = -2.58843552E+00 Max = 2.87629934E+00)
Were these information interpolated from something?
Is there any suggestion?
Thanks in advance,
Re: High output amplitutes in tidal simulation
#2 Unread post by wilkin »
Are you using the source from myroms.org, ROMS IRD/Agrif, or ROMS UCLA?
If the myroms.org source, then I'm not so sure the tidal forcing input values are reasonable:
The default units for the tide period are indicated in varinfo.dat as hours. On input these are converted to seconds and reported to stdout (above). You have a max tide period of 2.38071599E+06 seconds, or 786 hours.
The default units for tidal elevation are meters. You have 2.11612036E+01 which is 21.1 meters.
I suspect several of your other inputs are also wrong.
If you are not using the myroms.org source, or have scaled your inputs using the scale factor option provided by varinfo.dat, then let us know in your next posting because it affects how to tackle your problem.
John.
dhson
#3 Unread post by dhson »
Thanks for you reply
I'm using ROMS UCLA (trunk-r186, trunk-r195, trunk-r200, etc and they are all the same problem). I haven't modified any thing in varinfo.dat yet. Here is the related variable:
! Tidal forcing variables.
'tide_period' ! Input
'tidal period'
'hours' ! [s]
'tide_period, scalar, series'
'tide_period'
'idTper'
'nulvar'
3600.0d0 ! 60*60
'tide_Eamp' ! Input
'tidal elevation amplitude'
'meter' ! [m]
'SSH_Tamp, scalar, series'
'tide_period'
'idTzam'
'r2dvar'
1.0d0
Thanks again.
dhson.
#4 Unread post by wilkin »
You say you are using ...
I didn't think UCLA ROMS did the I/O this way - with varinfo.dat, or maintained an svn repository (i.e. with a trunk etc.) Are you actually using the source downloaded from myroms.org (a.k.a Rutgers ROMS)?
From varinfo.dat your tide period input has to be in hours, because you have a scale factor of 3600 which converts the hours to seconds. The units in square brackets [s] show this is what ROMS requires once your data are read and your scale factor is applied.
The stdout from the run reports a maximum period for the constituents of 2.38071599E+06 seconds, which is 661 hours (or 27.55 days). Is this what you intended? You have a minimum period for the constituents of 4.308E+04 which is 11.96 hours, which is right for the K2 constituent. So it looks to me that your tide periods are plausible.
However, I must assume the tide amplitude is wrong. stdout reports a maximum amplitude of 21 meters. I strongly suspect Roms_tools has given you data in centimeters. Perhaps this is documented in the tides file itself. Do:
 ncdump -h your_tides_file.nc
and look at the attributes of tide_Eamp. Check the values too.
If you think these are in centimeters, then you can either:
(a) modify the data in the file to convert to meters, or
(b) set the scale factor in varinfo.dat to 0.01 to make the conversion on input
John.
dhson
#5 Unread post by dhson »
Dear Jonh,
In fact, update ROMS version 3.1 from trunks did not take much time to modify so we prefer this way.
Unfortunately, I did not find any problem in the tidal forcing file:
double tide_period(tide_period) ;
tide_period:long_name = "Tide angular period" ;
tide_period:units = "Hours" ;
double tide_Ephase(tide_period, eta_rho, xi_rho) ;
tide_Ephase:long_name = "Tidal elevation phase angle" ;
tide_Ephase:units = "Degrees" ;
double tide_Eamp(tide_period, eta_rho, xi_rho) ;
tide_Eamp:long_name = "Tidal elevation amplitude" ;
tide_Eamp:units = "Meter" ;
double tide_Cmin(tide_period, eta_rho, xi_rho) ;
tide_Cmin:long_name = "Tidal current ellipse semi-minor axis" ;
tide_Cmin:units = "Meter second-1" ;
double tide_Cmax(tide_period, eta_rho, xi_rho) ;
tide_Cmax:long_name = "Tidal current, ellipse semi-major axis" ;
tide_Cmax:units = "Meter second-1" ;
double tide_Cangle(tide_period, eta_rho, xi_rho) ;
tide_Cangle:long_name = "Tidal current inclination angle" ;
tide_Cangle:units = "Degrees between semi-major axis and East" ;
double tide_Cphase(tide_period, eta_rho, xi_rho) ;
tide_Cphase:long_name = "Tidal current phase angle" ;
tide_Cphase:units = "Degrees" ;
I guess there were some bugs in coding.
