This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by GNU make configure 3.81, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ ./configure
## Platform. ##
hostname = darpan.npol.org
uname -m = x86_64
uname -r = 2.4.21-20.ELsmp
uname -s = Linux
uname -v = #1 SMP Sat Sep 18 18:28:16 PDT 2004
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = x86_64
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/jdk1.5.0_04/bin
PATH: /shared/Matlab2006b/bin
PATH: /shared/nagesh/gfortran/gcc-4.2/bin
PATH: /usr/kerberos/sbin
PATH: /usr/kerberos/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /sbin
PATH: /bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /usr/X11R6/bin
PATH: /opt/c3-4/
PATH: /opt/ganglia/bin
PATH: /opt/maui/bin
PATH: /opt/torque/bin
PATH: /opt/torque/sbin
PATH: /opt/rocks/bin
PATH: /opt/rocks/sbin
PATH: /shared/netcdf/bin
PATH: /shared/FortranCompiler/intel_fc_80/bin
PATH: /root/bin
## Core tests. ##
configure
![:1385:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1385.svg)
checking for a BSD-compatible install
configure
![:1440:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1440.svg)
result: /usr/bin/install -c
configure
![:1451:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1451.svg)
checking whether build environment is sane
configure
![:1494:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1494.svg)
result: yes
configure
![:1559:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1559.svg)
checking for gawk
configure
![:1575:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1575.svg)
found /bin/gawk
configure
![:1585:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1585.svg)
result: gawk
configure
![:1595:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1595.svg)
checking whether make sets $(MAKE)
configure
![:1615:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1615.svg)
result: yes
configure
![:1831:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1831.svg)
checking for gcc
configure
![:1847:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1847.svg)
found /shared/nagesh/gfortran/gcc-4.2/bin/gcc
configure
![:1857:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1857.svg)
result: gcc
configure
![:2101:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2101.svg)
checking for C compiler version
configure
![:2104:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2104.svg)
gcc --version </dev>&5
gcc (GCC) 4.2.4 20080220 (prerelease)
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure
![:2107:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2107.svg)
$? = 0
configure
![:2109:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2109.svg)
gcc -v </dev>&5
Using built-in specs.
Target: x86_64-unknown-linux-gnu
Configured with: /projects/tob/gcc-4_2-branch/configure --enable-languages=c,fortran --prefix=/projects/tob/gcc-4.2
Thread model: posix
gcc version 4.2.4 20080220 (prerelease)
configure
![:2112:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2112.svg)
$? = 0
configure
![:2114:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2114.svg)
gcc -V </dev>&5
gcc: '-V' option must have argument
configure
![:2117:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2117.svg)
$? = 1
configure
![:2140:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2140.svg)
checking for C compiler default output file name
configure
![:2143:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2143.svg)
gcc conftest.c >&5
/usr/bin/ld: unrecognized option '--as-needed'
/usr/bin/ld: use the --help option for usage information
configure
![:2146:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2146.svg)
$? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "GNU make"
| #define PACKAGE_TARNAME "make"
| #define PACKAGE_VERSION "3.81"
| #define PACKAGE_STRING "GNU make 3.81"
| #define PACKAGE_BUGREPORT "
bug-make@gnu.org"
| #define PACKAGE "make"
| #define VERSION "3.81"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure
![:2185:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/2185.svg)
error: C compiler cannot create executables
See `config.log' for more details.
## Cache variables. ##
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
## Output variables. ##
ACLOCAL='${SHELL} /shared/nagesh/gmake_3.81/make-3.81/config/missing --run aclocal-1.9'
ALLOCA=''
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='${SHELL} /shared/nagesh/gmake_3.81/make-3.81/config/missing --run tar'
ANSI2KNR=''
AR=''
AUTOCONF='${SHELL} /shared/nagesh/gmake_3.81/make-3.81/config/missing --run autoconf'
AUTOHEADER='${SHELL} /shared/nagesh/gmake_3.81/make-3.81/config/missing --run autoheader'
AUTOMAKE='${SHELL} /shared/nagesh/gmake_3.81/make-3.81/config/missing --run automake-1.9'
AWK='gawk'
CC='gcc'
CCDEPMODE=''
CFLAGS=''
CPP=''
CPPFLAGS=''
CYGPATH_W='echo'
DEFS=''
DEPDIR=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
GETLOADAVG_LIBS=''
GLOBINC=''
GLOBLIB=''
GMSGFMT=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
INTLLIBS=''
KMEM_GROUP=''
LDFLAGS=''
LIBICONV=''
LIBINTL=''
LIBOBJS=''
LIBS=''
LTLIBICONV=''
LTLIBINTL=''
LTLIBOBJS=''
MAKEINFO='${SHELL} /shared/nagesh/gmake_3.81/make-3.81/config/missing --run makeinfo'
MAKE_HOST=''
MKINSTALLDIRS=''
MSGFMT=''
MSGMERGE=''
NEED_SETGID=''
OBJEXT=''
PACKAGE='make'
PACKAGE_BUGREPORT='
bug-make@gnu.org'
PACKAGE_NAME='GNU make'
PACKAGE_STRING='GNU make 3.81'
PACKAGE_TARNAME='make'
PACKAGE_VERSION='3.81'
PATH_SEPARATOR=':'
PERL=''
POSUB=''
RANLIB=''
REMOTE=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
U=''
USE_CUSTOMS_FALSE=''
USE_CUSTOMS_TRUE=''
USE_LOCAL_GLOB_FALSE=''
USE_LOCAL_GLOB_TRUE=''
USE_NLS=''
VERSION='3.81'
WINDOWSENV_FALSE=''
WINDOWSENV_TRUE=''
XGETTEXT=''
ac_ct_CC='gcc'
ac_ct_RANLIB=''
ac_ct_STRIP=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__include=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build=''
build_alias=''
build_cpu=''
build_os=''
build_vendor=''
datadir='${prefix}/share'
exec_prefix='NONE'
host=''
host_alias=''
host_cpu=''
host_os=''
host_vendor=''
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/shared/nagesh/gmake_3.81/make-3.81/config/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
mkdir_p='mkdir -p --'
oldincludedir='/usr/include'
prefix='NONE'
program_transform_name='s,x,x,'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## Output files. ##
MAINT_MAKEFILE=''
## confdefs.h. ##
bug-make@gnu.org"
configure: exit 77
