I turned on #define STATIONS, created a stations.in file, and set some of the Sout(idBott) parameters. I get water column values and I also get mud_01, mud_02, but I don't get any bed surface parameters. I also can't seem to figure out where in the code it turns on writing out bed parameters like fraction and porosity. I have these turned on in sediment.in, but do you also turn them on in station.in?
Is there a typo in inp_par.F? In the stations section, a line reads:
ELSE IF (TRIM(KeyWord).eq.'Hout(idBott)') THEN
