After Kate suggestion I had tried to install the basic requirements for ROMS. I installed gfortran compiler, ifort compiler, netcdf-3.6.2. I tried to compile the code.
When I tried to compile the ROMS-3.0 code with gfortran I got the following error:
My desktop is RHEL-3.0 and tried first with single processor (serial mode).makefile:32: *** This makefile requires one of GNU make version 3.80 3.81.. Stop.
I find that GNU make which I am having is 3.79.1.
What I have to do now?
Then I went for ROMS-2.2 with ifort. I got the following error:
I think I didnt give the correct options in Linux-ifort.mk. I had given only the netcdf paths in that file. I didnt change anything else.ld: skipping incompatible /shared/nagesh/netcdf/lib/libnetcdf.a when searching for -lnetcdf
ld: cannot find -lnetcdf
gmake: *** [/shared/nagesh/ROMS-2.2/Ocean_S] Error 1
I giving here the info about my O.S.:
AMD opteron 64-bit processor RHEL-3.0
I tried to search the previous posts but I couldnt understand what to do.
Any help is appreciated.
Thanks in advance.
With best regards,
G.NageswaraRao.
