version 168 aborts compilation
rubash
#1 Unread post by rubash »
Compilation of version aborts with this message:
cd Build; mpif90 -c -frepack-arrays -O3 -ffast-math abort.f90
 In file abort.f90:15
      USE ocean_control_mod, ONLY : ROMS_finalize
                                  1
Error: Symbol 'roms_finalize' referenced at (1) not found in module 'ocean_control_mod'
make: *** [Build/abort.o] Error 1
#2 Unread post by arango »
The routine ROMS_finalize should be available in your compiled file Build/ocean_control.f90. The only thing that I noticed is that Utility/abort.F is calling:
!  Finalize ROMS component.
      CALL ROMS_Finalize
Here ROMS_Finalize is with uppercase F. It seems that your compiler is case sensitive for subrotines calls. That's weird. Try changing that call to
      CALL ROMS_finalize
to see what happens.
rubash
#3 Unread post by rubash »
Ok, that worked.
