doubt about installing roms-3.0
nageswararao
#1 Unread post by nageswararao »
I joined to new organisation, in that there is not internet facility. I want to install ROMS-3.0. Will it be possible for me to install ? ;since new version is distributed and updated through svn version.
With best regards,
G.NageswaraRao.
How do they expect you to do your job without internet? I get my winds and boundary conditions via internet too, more so with every passing year.
nageswararao
#3 Unread post by nageswararao »
Yes, they will permit me to install ROMS-3.0. I have data of all the fields.
nageswararao
#4 Unread post by nageswararao »
In library there is internet. From there I am trying to download ROMS-3.0 code using smartsvn on windows platform. But i am getting following error
svn: PROFIND request failed on '/svn/src/trunk'
svn:www.myroms.org
I had given the following url for Enter SVN URL https://www.myroms.org/svn/src/trunk
Then, I clicked next
then, I gave username 'nageswararao' and password of my roms account
then, I click next, while processing it gave the above error.
Can anybody tell me why it was happened and how can recover from it?
Thanks in advance.
With regards,
G.NageswaraRao.
linzhenhua
#5 Unread post by linzhenhua »
Hello
I have never used smartsvn but hope to provide some information to you.
It has been reported that one will have trouble if he first check out roms source code to a windows platform and then upload to a linux OS. So even though you can get the source code successfully,you will have trouble later.
nageswararao
#6 Unread post by nageswararao »
I got the code. It's not ur mistake. Here my office library systems are not allowing to connect to ur server. I downloaded the code outside.
Thanks for ur response.
With best regards,
G.NageswaraRao.
abever
#7 Unread post by abever »
As preemptive info you may already know.
You will have to change all the line endings in all the files if you are not running it in Windows.
In Linux/Unix this can be done with the recode command.
